Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 11-11-2008, 07:21 PM
phantomwarrior1 is on a distinguished road
Craftsman Model 109 benchtop metal lathe
I can get one of these mad cheap. Is this a good lathe in anyway or can this be a nice cheap lathe to experiment on in any way. Thanks
Old 11-12-2008, 10:50 AM
acondit's Avatar
acondit is on a distinguished road
The 109 is not worth spending time on IMHO. I had one and the spindle is way too skinny for anything but the lightest work. Its spindle is only like 1/2" in diameter. The seig mini-lathe is much beefier than the 109 (costs more too). OTOH, the other style Craftsman 6" lathe is reasonably good. I have seen a lot of nice work done on one of them (if you can find one for a reasonable price).
Alan
http://www.alansmachineworks.com
Old 11-13-2008, 09:04 PM
LUCKY13 is on a distinguished road
The 109 is what it is, but I have seen many people use these lathes with very good results. Ofcourse they knew what they where doing and worked on the lathes to help in ways they need. If the 109 is dirt cheap and it would be a first lathe I would go for it. Just remember things can start snowballing on you and before you know you have enough money in something that you could have bought a better machine. Having plenty of assy & tooling could help on the worth of the lathe. If you have to start buying chucks, change gears and tooling it will add up quick.
I see these lathes go for around $300.00 alot on Ebag, so if you can get it cheap/cheap ($100.00 or less ) you can always get your mooney back after you have played with it and got your feet wet.
Here is a good link with parts and lots of info on these little lathes. If I find one cheap enough close to home I would buy it myself, but you have to remember they are what they are. I like them myself, and where they have become quite a collectable item, returning your money if keep in good shape is no problem.
http://www.homeshopsupply.com/index.html
Jess
Old 11-13-2008, 11:28 PM
crsatter is on a distinguished road
Just my two cents
Buy what you can afford. Depending on what you are going to do the 109 is going to be limited in what you will be able to do. They are less expensive than new and there are a lot of inexpensive parts, tools and accessories avaliable on e-bay. When you upgrade to something with more power what you have learned may keep you from damaging the lathe or more important yourself. Remember the accessories can add up to more than you spent on the lathe.
Have fun be Safe.
Old 02-11-2010, 09:04 PM
jayhawkman is on a distinguished road
109 parts
If anyone is needing a new spindle(made from 4140) or bearings give me a call at 913 636 6107. Thanks Mike
Old 02-12-2010, 12:38 AM
asuratman is on a distinguished road
Hello jayhawkman,
Can you post any pictures your pindle or your website. Thanks.
Craftsman 6 X 18 Metal Lathe Part Needed Mr.Chips Mini Lathe 13 04-29-2011 08:19 PM
Atlas Craftsman 6" lathe mod. 109 21270 Cropduster Mini Lathe 7 10-14-2009 05:18 PM
Conversion of Atlas/Craftsman lathe? jgourlay Mini Lathe 9 08-31-2007 12:50 AM
Anyone here have a Craftsman/Atlas Lathe? ZipSnipe Mini Lathe 8 03-29-2006 05:08 PM
belt numbers for 6" Craftsman Lathe? shootingarts General Metal Working Machines 2 02-08-2006 08:29 PM
