Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 10-11-2004, 03:28 PM
balsaman's Avatar
balsaman is on a distinguished road
Quick release tail stock on 8x12 lathe
I modified my tail stock for quick release, being tired of cranking that big bolt all the time. Here it is completed.
I wish it wouldn't crash.
Old 10-11-2004, 03:29 PM
balsaman's Avatar
I had to drill a 1/2" hole in the tail stock.
Old 10-11-2004, 03:31 PM
balsaman's Avatar
I made a new bolt from 3/8" treaded rod. I welded a nut to the end and drilled it out to 3/8". I made a new nut for the bottom too.
Old 10-11-2004, 03:33 PM
balsaman's Avatar
I took a chunk of 1/2" steel round stock, turned it in my 4 jaw and make a 3/8" "cam". I then put it back in my 3 jaw and turned the end down to 1/4". I drilled and tapped the end for 4/40 for a retaining screw. In the picture there is a spacer and a 1.5" round peice that the handle screws into.
Old 10-11-2004, 03:38 PM
balsaman's Avatar
I made an aluminum block with a 1/4" hole to support the unsupported end. A bolt keeps it all together. When I get my milling machine, I will mill a flat spot on the tail stock casting so the block will sit flat and look more profesional.
Old 10-11-2004, 03:40 PM
balsaman's Avatar
The drilled out nut on the bolt sits on the cam. Moving the handle about 45 degrees changes things from loose to tight. Works great.
Old 10-12-2004, 05:53 AM
rob2424 is on a distinguished road
what is the make and model of your
lathe?
Old 10-12-2004, 07:14 AM
balsaman's Avatar
Harbor Freight 8x12
Old 10-12-2004, 08:40 AM
Gold Member
Ken_Shea is on a distinguished road
Excellent Balsaman !!
Old 10-12-2004, 08:41 AM
Gold Member
JFettig is on a distinguished road
I sure wish my tailstock on my 7x12 was that wide so it wouldnt tip when I try to slide it.
I was trying to sceme up an idea to make it wider
That definately looks very nice. one thing I have wanted to put on mine is a crank on the end of the leadscrew *hint* *hint*
Jon
OneCNC XR Series Lathe CAD/CAM Released: OneCNC Product Announcements & Manufacturer News 0 03-07-2005 05:20 PM
head stock and tail stock chucks mocnc DIY-CNC Router Table Machines 3 10-19-2004 10:16 PM
