Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 09-18-2004, 12:38 PM
gdl357's Avatar
Lathe Novice
gdl357 is on a distinguished road
Post El Cheapo Knurler Tool completed!
Hi there, I just completed a knurler tool el cheapo style. Works like a charm. Now I can put the money I saved on my Chuck. HAHA
Plans are here http://www.cartertools.com/knurl.html
Name:	knurler tool.jpg‎
Old 09-18-2004, 05:29 PM
Konstantin's Avatar
Konstantin is on a distinguished road
Great.
Many thanks for sharing.
Konstantin
Old 09-18-2004, 08:03 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Very nice I'll be making one for myself.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 09-18-2004, 09:22 PM
anoel's Avatar
anoel is on a distinguished road
Very cool. I just finished making the Knurling tool posted over at LittleMachineshop.com as my first "real" machining exercise. I'll try to snap a picture of it I think that it turned out pretty good considering that it's the first metal thing I ever made.
Nathan
Old 09-18-2004, 10:25 PM
Konrad's Avatar
Konrad is on a distinguished road
Very nice, thanks for sharing!
something puzzles me, how does the tool center itself on the shaft,
can you post a pic. when in operation.
thanks,
Konrad
Old 09-18-2004, 11:13 PM
gdl357's Avatar
Lathe Novice
Thumbs up
The tool is centered with the tool post and the cross slide for vertical and horizontal adjustment. Also when you tighten it up it will correct and place itself around the round bar. Very easy to use. I kept it on my original toolpost and not on the QTP. I had to place a 2 3/4" x 1/2" x 1/8" spacer under the knurler tool to raise it up to center. That can be fixed by using a QTP or bolting it up to the aluminum block like the author did.
In my pics, I did not adjust it 100%, the wheels are just a lttle over the center point. One turn on the cross slide and it would have been corrected. Just for picture taking.
It works great.
--- Updated my Pc camera drivers, now the pics are bigger and clearer. Not bad for a cheesy $30 Intel Pc camera.
ID:	3438   Click image for larger version
ID:	3439   Click image for larger version
ID:	3440   Click image for larger version
ID:	3442   Click image for larger version
Last edited by gdl357; 09-18-2004 at 11:24 PM. Reason: It feels great when a project works after spending so much time on it.
Old 09-18-2004, 11:47 PM
Konrad's Avatar
O.K. that makes sense!
thanks again!
Konrad
Old 09-19-2004, 03:57 PM
Konstantin's Avatar
Yo gdl357 .
What lathe do you use?
Konstantin
Old 09-19-2004, 04:50 PM
anoel's Avatar
Here's my knulrer
Here are pics of the LMS knurler that I did for my first machining excersize.
ID:	3446   Click image for larger version
Nathan
Old 09-19-2004, 05:04 PM
gdl357's Avatar
Lathe Novice
Talking
Yo gdl357 .
Konstantin
I Own a Micro-Mark 7x14 Version #82710 with Digital Readouts so it can do mm or SAE. My first lathe, and am happy with my purchase. I did want a JET lathe, but that was too big.
http://www.mini-lathe.com/Mini_lathe...Micro-Mark.htm
******Update*******
Just a quick mod to the knurler.
Drill an extra set of holes closer to the center hole so u can screw the upper and lower pieces closer to the center so they wont have a rediculous angle when you knurl small round like 1/4". This way you will have two settings, one for over 3/4" and one for below. 1/4" closer to the center hole is good.
something like this
[_o__o_______o_______o__o_]
Line art.
.:: gdl357 ::.
What is high speed machining Klox Hard and High Speed Machining 111 01-26-2011 01:21 PM
HELP Tool changer problems ddprecision Haas Mills 9 01-14-2011 05:24 PM
Tool length sensing! Swede FlashCut CNC 15 10-12-2005 08:51 PM
Miniature Automatic Tool Changer 1ctoolfool Product Announcements & Manufacturer News 1 04-18-2005 06:56 AM
Tool Changer Problems Snel Haas Mills 5 08-11-2004 09:56 AM
