| Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here. |
| CNC lathe design discussion Any idea's for making a CNC lathe? Here is a great picture of one-
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com |
| It is desireable to have the bed a broad as possible. The way this long cross slide cantelevers out over the bed would be a recipe for chatter. Can a tail stock be fitted?
__________________ Regards, Mark www.wrathall.com |
| I am in the middle of building one right now. Should be a few weeks at the most till I am done and making parts. It has a 36" overall work envelope, and the head will except up to 2-1/4" dia. stock. I am making the head myself. There will be 2 axis of cnc and one axis of manual for depth control. I will submit pics as soon as I can. Can't wait (neither can my customer) Glen |
| Take a look through Stevie's long thread. Sorry, don't have time to find a link right now. But I think it's in the general metalworking forum.
| Looking forward to those pics. A T-slotted cross slide is a real bonus.
| Once I get some time, that will be my next project building a CNC lathe, for the stuff I make it would be perfect.
| A few years ago, I brainstormed doing a big-bore (3 inch dia") CNC lathe from scratch. Regarding the photo (hope it uploads!), it is fashioned out of only two pieces of sheet steel (cardboard here). One piece is the vast majority of it, (plasma, waterjet or laser cut) and folded, then welded along some of the seams. One thicker piece (say 3/8") forms the insert where you see the chuck (tin pot) hanging off it. This piece gives rigidity to the whole structure. Note the X, Z and feedrate override knobs (margarine containers!) and big 4" voltage & amperage analog guages. The bedway would be a 12"*12"*48" cast iron block, cut lengthwise into four 12" wide * 3" high * 48"L beds (to make four lathes). They would then be ground. On the inside of the cabinet, another 12"*12"*18" solid block of cast iron would be machined to fit a few big taper roller bearings and the spindle, then bolted to the main bed. The spindle motor (3 - 5 HP) would cog-belt drive the spindle through either a low speed pulley set, or a high speed pulley combo (manually changable). In the backside, there is a big 4" depth space for electronics & coolant pumps etc. The rest, (carriage, cross-slide, power chuck) I haven't figured out yet. Any interest out there in this type of project? Probably would have to sell for at least $10K, as making it would be a lot of work. On the other hand, thats cheap for a 3-4" bore cnc lathe. cheers Doug Fortune |
| Thanks alot all Last edited by Red_Turbine; 09-19-2006 at 01:23 AM. |
#10
| follow the lathemaster thread or the HF 9x20 to cnc. i'm currently working on converting my 9x20 lathe to cnc. it takes some engineering but since i'm a mech E i think i've got most of if figured out. |
#11
| Thanks alot Last edited by Red_Turbine; 09-19-2006 at 01:20 AM. |
#12
| I am building my own cnc lathe with THK rails and custom cast iron frame. Here is a (not-so-finished) 3D model of the design. [for size comparison, the chuck is 100mm (4")] |
