Results 1 to 6 of 6
Thread: 8x14 Wiring
    Jan 2006
    8x14 Wiring
    Hello, I am reinstalling my ac motor on my LM 8x14. I would imagine the HF 8x12 is the same and I cannot remember how it is wired. On the switch I have 4 wires, labeled d1,d2,k1,k2. On the motor I have ground(obvious), u1,u2,z1,z2. I need to have this reversible so I can metric thread. Any pictures or help would be appreciated. Thank you
    Nov 2005
    Alabama - USA
    The wiring info is here.
    http://www.lathemaster.com/images/LA...NUAL%20PDF.pdf
    The Harbor Freight manual has no wiring info.
    I'm about to leave, but if that isn't enough and no one else chimes in I can look at my HF later today.
    Jan 2006
    Hey Mike if you wouldnt mind taking a look I would really appreciate it. Wiring is not my forte and I dont understand the schematic well enough to feel comfortable. Thank you
    Damien
    Nov 2005
    Alabama - USA
    Here it is. I didn't pull the covers to get to the motor to see what the numbers (if any) were on the motor leads. Hopefully, your motor has the same colors. I did notice it is not wired like the Lathemaster manual shows.
    Attached Thumbnails Attached Thumbnails 8x14 Wiring-hf_44859_8_x_12_lathe_wiring.gif
    Jan 2006
    Hey Mike, thank you very much. Ill check tomorrow to see if I can work it up to the wire leads. Thank you again.
    Dec 2007
    Quote Originally Posted by Mike Nash View Post
    That diagram looks right to me... Their is a panel on the back which is held on by 4 small hex machine screws, All of the wires are behind this panel.
    Really, the wiring diagram is dependant on the switch you have, if you google the part number of the switch you should be able to find a datasheet and wiring diagram.
    1. Installed tach on 8x14
      By arekugi in forum Mini Lathe
      Last Post: 02-18-2008, 01:19 AM
    2. LM 8x14 or HF 8x12?
      By TMaster in forum Mini Lathe
      Last Post: 08-21-2007, 07:05 PM
    3. 8x14 timing belt
      By thesh111t in forum Mini Lathe
      Last Post: 12-13-2006, 01:12 AM
    4. LatheMaster 8x14
      By Brass_Machine in forum Mini Lathe
      Last Post: 09-30-2006, 03:02 PM
    5. seriously considering lathemaster 8x14
      By whelzorn in forum General Metal Working Machines
      Last Post: 09-21-2005, 11:21 PM
