Results 1 to 2 of 2
Thread: Metric Threading
    Nov 2007
    Metric Threading
    ]I have a Harbor freight 9 x 20 lathe,sometime in the near future I will want to purchase a blank backplate for a 6" 4 jaw chuck. My dream is to completely machine it to fit the chuck including cutting the threads. I believe the thread is an M39 x 4.
    If anyone out there has already done this would they be willing to share there experiences as to,"How To Go About It".
    Most important is it Possible to do this on the 9 x 20 considering it's size?
    If Possible:
    1 - Is the thread angle same as the American thread (60 Degrees)
    2 - What are the two gears required (a & b) and are they commerically available to fit the 9 x 20,also is there an estimated cost.
    3 - Is the procedure the same as the American procedure and what angle is the compoud rest set
    Any suggestions recommendations greatly appreciated.
    Regards
    John Romano
    Registered acondit's Avatar
    Apr 2005
    John,
    Not to put a damper on enthusiasm, but why not buy one already threaded from LMS (Little Machine Shop).
    http://www.littlemachineshop.com/pro...ProductID=1922
    They only cost thirty bucks and the hardest part is already done.
    However, if you insist, then here is the info on the gear setup. I show how to fit a new back plate and chuck on my website. Steve Bedair made one from scratch from a hunk of steel on his lathe.
    Alan
    Attached Files Attached Files
  1. For the love of GOD use metric!
    By Heavy in forum JGRO Router Table Design
    Last Post: 11-21-2008, 06:54 AM
  2. looking for metric plans
    By stem fan1 in forum Steam Engines
    Last Post: 03-24-2008, 10:54 PM
  3. Where to get 6061 hex in metric?
    By grinderdust in forum General Metalwork Discussion
    Last Post: 10-07-2007, 10:22 AM
  4. Metric Threads
    By jackson in forum General Metalwork Discussion
    Last Post: 08-16-2007, 09:10 AM
  5. Help whit ini Metric
    By essa in forum LinuxCNC (formerly EMC2)
    Last Post: 04-13-2006, 03:19 PM
