Results 1 to 4 of 4
Thread: External Threads
    Nov 2007
    External Threads
    When cutting external threads,is the outside diameter cut to the "Basic Major Diameter" listed on the charts?
    Example: Do you turn down the work piece to 0.236 inches for a M6 x 1.0
    thread?
    Also is this diameter the same whether you are cutting threads with a die compared to cutting threads on a lathe.
    I would appreciate any comments or suggestions.
    John
    Registered fatal-exception's Avatar
    Mar 2006
    Turn the rod down to a value between the min and max OD as listed on most screw charts or in the Machinerys Handbook.
    Yes, you would use the same diameter regardless of how the threads are cut.
    Mar 2008
    Pasco
    Thread Cutting
    When cutting an external Thread the outside diameter the same as the one on the charts for Instance 5/8 x 11 world be turned to .625 I usually cut about .003 to .oo4 smaller, I can only speak for myself but this causes less interference when you go to put it in a mating female part such as a nut the same size, it is a good idea to have a mating part that you know is to size that way when you are finished with the thread you can check it to make sure it fits! For Metric Thread, use .03937 for instance 6 x .03937 = .23621 to go back the other way you would divide
    a1woody1
    Mar 2006
    John, according to the machinerys handbook:
    M6x1-6h: maj dia max = 5.974 (.235"); min = 5.794 (.228")
    min dia max = 4.891 (.193"); min = 4.596 (.181")
    If your cutting with a die, you can relax these dims since the die will correct. If your threading on the lathe, be within the above tolerance or it will take trial and error to fit properly.
    a1woody1 - you can use your generalization for large threads (1/4" and up) but for smaller threads, -0.004 could be way out of tolerance.
    If possible, you should consult a real screw chart that shows the limits of both the major and minor diameter.
  1. Any easy way to add an external feedrate?
    By Chris64 in forum Mach Software (ArtSoft software)
    Last Post: 02-01-2008, 05:01 AM
  2. External Threading
    By skipper in forum General Metalwork Discussion
    Last Post: 10-26-2007, 10:19 PM
  3. External cmos battery?
    By MegaMoog in forum Bridgeport and Hardinge Mills
    Last Post: 10-29-2006, 07:51 PM
  4. external start stop
    By drk in forum Carken Products (Deskam, DeskCNC etc)
    Last Post: 03-31-2005, 11:21 AM
  5. Saving threads or parts of threads???
    By flybynight in forum Forum Questions or Problems
    Last Post: 02-22-2004, 01:19 AM
