Results 1 to 8 of 8
Thread: WW Collet Info
    Apr 2004
    Illinois
    WW Collet Info
    Does anyone have the dimensions and angle of the WW collet used in the sherline. Or can someone that has one measure the collet for me. I am designing a machine and would like to use this collet but need to see what the diamater of the spindle shaft ends up after I machine the taper . I really don't want to buy one as I would like to get this design done before the time it takes for sherline to ship one to me. Any help would be greatly appreciated.
    Dimensions that I need are:
    Overall lenght taper angle and lenght of taper, barrel lenght and diameter, keyway size , and if there is any taper on the barrel .
    Jim Walthall
    Registered neilw20's Avatar
    Jun 2007
    Post This might help.
    Have a look in this pdf. Your collet might be here.
    Last edited by ger21; 03-06-2008 at 08:38 PM. Reason: removed copyrighted material
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Jun 2007
    That file doesn't have WW collets...
    Sherline's site only states:
    Sherline WW collets that have a shank diameter of .312-.313". Other manufacturers make collets that vary in size up to .314-.315"
    The larger size is referred to as an 8mm collet....
    Apr 2004
    Illinois
    Thanks for the replies .I have ordered a collet from Sherline and sould have it by the first of the week.
    Cheers,
    Jim Walthall
    Jul 2007
    Norway
    neilw20.
    I searched and found this thread. That documetn is just what I needed. thanks
    Jul 2005
    Quote Originally Posted by tahustvedt View Post
    neilw20.
    It does not appear to give the angle of the taper. AT least I do not seem to be able to find it.
    May 2008
    degrees of separation
    The Sherline document says to true the adapter to 20 degrees, so I'd bet the collet angle is ..... 20 degrees.
    Yes, I know I'm 2 years too late
    Registered knudsen's Avatar
    Feb 2010
    What good is it if it's not worth waiting two years for?
    I thunk those were like C3 collets or something.
    1. What style of collet do you run?
      By Chuck Reamer in forum CNC Tooling
      Last Post: 02-18-2007, 12:59 PM
    2. Need Collet Help
      By opmi in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 01-26-2007, 07:58 PM
    3. collet
      By Smackre in forum WoodWorking
      Last Post: 05-12-2006, 07:58 PM
    4. collet adapter
      By truman in forum General Metalwork Discussion
      Last Post: 03-24-2006, 09:43 PM
    5. R8 Collet pressure
      By JFettig in forum General Metal Working Machines
      Last Post: 09-27-2004, 11:38 PM
