| Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here. |
I know i read this somewhere before but I cant seem to find any info on the best way to clean up the carriage casting on my 9x20 grizzly lathe. specifically the carriage ways. Im converting it to a cnc and when I took it apart I noticed that the ways where terrible. I mean there not even flat. It looks like somebody went at them with an angle grinder. so i wanted to try and clean them up but dont know the best way to approach this. any one out there got some tips or can point me to an article covering this. Thanks Chris |
| if they are that bad the only option is lapping them. get some lapping compound and have at it. i don't know if there are any instructions for this particular machine on how to do it. mine aren't that bad. if you just bought the machine i would suggest sending it back. |
Show us a photo of what you are talking about. Are you talking about the top side of the ways or the underside edges? Alan
__________________ http://www.alansmachineworks.com |
| Im talking about under the carriage where it rests on the ways. It clearly only contacts the ways in two very small areas on each edge of the carriage. I thought I read somewhere that I could maybe very carfully mill it down to make it mate to the ways better as of right now Id say the contact surface area is less than a square inch. I will try and take a photo later for you guys. Chris |
The problem you face is that there is an angular way also that helps control alignment of the carriage. When you start messing with one surface on the carriage, you effect the fit to the other ways as well. Alan
| Looking to link the carriage to the headstock spindle | MR.20C | Wood Lathes / Mills | 17 | 10-21-2007 10:39 PM |
| Bearing carriage running on an angle profile instead of using round tube | Menno | JGRO Router Table Design | 8 | 01-02-2007 07:00 AM |
| Building a Solid Carriage Stop for my Lathe! | widgitmaster | Vertical Mill, Lathe Project Log | 22 | 10-29-2006 09:13 PM |
| Check Carriage Sensor or VC Motor | jstovall | Printing, Scanners, Vinyl cutting and Plotters | 1 | 10-16-2006 08:52 PM |
| Rails to bearings to carriage to... drive system? | Losos | DIY-CNC Router Table Machines | 2 | 01-11-2005 01:40 AM |
