Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 11-11-2007, 07:55 PM
KOS KOS is offline
KOS is on a distinguished road
HF 7x10 to 7x19 bed conversion
ok well I am not 100% sure on the measurement. But I used to have 2 of the 7x10 lathes until I decided to tear one down and mount it on my cnc'd X3 to make it into a turning center and 4th axis. So having the old table just sitting there I decided to cut it to fit the end of my other 7x10 to make it much larger.
I think with the live center it will have 16-18" between centers now. I called it a day before I got any further with it, but I just have to attach them together and order a new lead screw. I also have to attach the carriage travel teeth back on, and possible add some additional length to it..But I will see.
Here is a link to my thread for my mill, and I included some pics of my shop too..
http://www.cnczone.com/forums/showth...983#post364983
www.kosracing.com
Old 11-11-2007, 09:47 PM
KOS KOS is offline
ok went to measure it up and here is what I got.
So from the front of the headstock to the end of the bed is 28.25", and from the front of chuck to the end of the bed is 25.5".
With my live center in the tail stock and positioned all the way at the back of the bed, I measured 19.5" from the front of the chuck to the tip of the live center.
So for the sake of argument it can turn a 19" length pice. So 7x19 would be an acurate usable description of the lathe.
www.kosracing.com
Old 11-13-2007, 09:49 AM
KOS KOS is offline
Guess this is a common mod? No one seems that interested...
Well last night I got the bed clamped together and just ended up welding the seems shut, so not it is not going to go anywhere.
next thought is to use some angle iron to attach the bed to the table in a few more places. Also I am thinking to sealing off the bottom of that so I can pour in some portland cement or something to beef it up some and give it a little more rigidity..
Has anyone done this mod and also added in some more weight?
www.kosracing.com
Old 11-13-2007, 11:02 PM
S_J_H is on a distinguished road
Smile
Kos, pretty cool work. I used to have a 7x and had a lot of fun with it.
You might want to check out this group.
http://groups.yahoo.com/group/7x24Mini-LatheCNC/
Steve
Old 11-14-2007, 09:08 AM
KOS KOS is offline
Thanks Steve
I took a look at that group before and noticed it seemed pretty quiet as far as posts. Did you stretch your as well?
www.kosracing.com
Old 11-14-2007, 03:20 PM
Smile
KOS,
No I never really did much to modify my 7x10. I used it quite a bit though and had much enjoyment with it!
It's become a donor machine for parts now. I used the headstock and tail stock off of it for the cnc bench lathe I built.
Steve
Old 11-14-2007, 03:30 PM
KOS KOS is offline
Yeah I kind of did the same thing. Used on for my cnc mill as an extra attchment then extended this one. But I still have my 11x26 lathe as well.
I am excited to get the attachment done for the cnc though..
www.kosracing.com
Old 12-06-2007, 01:42 PM
RTP_Burnsville is on a distinguished road
Nice job..... I have thought about doing something similar to my 7x10. I like the lathe but the very short bed is a royal pain at times. FWIW, If you do an internet search you will find a few others that have done a similar conversion.
Robert
Old 12-09-2008, 12:05 PM
Farasien is on a distinguished road
How does your accuracy on this look?
I've thought of doing this to my 7X10 with several of the bed extention kits LMS sells, but from what I;ve heard, its a royal PITA to get the accuracy you once had without it. Have you found this to be true, and if so, how did you get the accuracy back?
-Farasien
jpg to dxf conversion jlenelms Machine Created Art 27 11-08-2007 12:20 AM
7x10 headstock collet holder? Tim Wiltse Mini Lathe 2 04-23-2007 08:43 PM
Non breaking... gear for 7x10 mini-lathe? jinu117 Mini Lathe 9 11-27-2006 08:11 AM
8x12 vs 7x10 sanddrag Mini Lathe 1 03-14-2006 11:08 PM
Take yer 7x10 to 7x14 with LMS upgrade kit rashid11 General Metal Working Machines 0 07-07-2005 09:33 PM
