Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 11-05-2007, 10:49 AM
life3970 is on a distinguished road
Surface Finish
I have a 7"x 10" HF mini lathe and I changed my gears for some threading. Now I want to change back to the correct gears for a smooth finish on the OD using the auto feed, but, I don't remember what gears I used. Help...thanks
Old 11-05-2007, 05:02 PM
maxboostbusa is on a distinguished road
If you go to Little Machine Shops site there is a information booklet you can view on the mini lathes. It tells about the change gears and what was stock.
Old 11-07-2007, 01:00 PM
pastera is on a distinguished road
256 TPI - 20,80,20,80
Aaron
Surface finish skmetal7 Mini Lathe 7 09-10-2007 01:56 PM
Surface finish chakaloso General Metal Working Machines 0 06-12-2007 09:54 PM
surface finish fadalman BobCad-Cam 2 03-03-2007 02:30 AM
Surface finish d.a.v.e Mechanical Calculations/Engineering Design 1 11-10-2006 02:35 PM
32 surface finish mroy0404 General Metalwork Discussion 4 05-28-2006 10:02 PM
