Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 10-18-2007, 04:42 PM
JPB JPB is offline
JPB is on a distinguished road
Teflon Plastic lathe machining
I was wondering if anyone had an idea on how you can break your chips while running plastic product on a cnc lathe
Old 10-18-2007, 11:03 PM
Big_d is on a distinguished road
To get a good cut and finish you have trouble breaking chips of Teflon. I have used a vacuum attachment on the tool post before to control the stream and keep the dust down.
Cheers
Darren
Old 10-22-2007, 12:39 PM
JPB JPB is offline
Thanks Darren, We use a vacuum but with tool changing and all we have to have to door open to hold the vacuum. thanks again.
Work Anyone ? - Machining Plastic Boxes bcdaus Australia, New Zealand Club house 1 07-23-2007 08:18 AM
Machining Plastic (Centriboard) what bit to use? abelloise Glass, Plastic and Stone 1 07-09-2007 12:01 AM
Machining Plastic (HDPE) Buzz9075 Glass, Plastic and Stone 11 07-01-2007 07:45 PM
Machining engineered plastic skykash2000 Test Forum 0 09-18-2005 09:34 AM
Tried using Teflon? Mr.Ed DIY-CNC Router Table Machines 22 08-02-2004 08:16 AM
