Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 10-18-2007, 01:45 PM
mwalach is on a distinguished road
How do I change autofeed direction?
How do I change autofeed direction on my Harbor freight model BV-920 lathe? It feeds into the headstock, not away from it. It will feed away from the head stock if I change the motor direction but then the spindle spins reverse as well. Is it ok to cut with the spindle spinning the wrong way? Is there a way to make it auto feed away from the headstock and still have the spindle rotate toward me?
(I'm relativly new to machining, only had one class back in college)
thanks.
www.bigbearcnc.com
Old 10-18-2007, 08:33 PM
acondit's Avatar
acondit is on a distinguished road
Mike,
You have to add an idler gear in the gear chain. That wil reverse the direction of the leadscrew relative to the rotation of the spindle.
Alan
http://www.alansmachineworks.com
Old 10-19-2007, 06:41 AM
in2steam is on a distinguished road
Its often refered to as the LH or left hand threading mod.
surf the web there are several good sites, don't limit the views of other lathes as they all pretty much work the same way 9x20 7x10 etc.
chris
Old 10-19-2007, 10:11 AM
KOS KOS is offline
KOS is on a distinguished road
well the 7x10 lathe actually is easy, all you have to do is flip the directional feed bar on theback of the lathe to change feed towards or away from the chuck. You can spin the chuck clockwise or counter clockwise as well. They already have that feature built into the lathe so no mods are required...not sure about the 9x20 though, my other lathe is the grizzly 11x26
Dan
EMC2 - Step/Direction Change Precharge NightHawk.Eng LinuxCNC (formerly EMC2) 3 08-13-2007 02:30 PM
i need to change the chucking direction !!! miguisu Fanuc 2 02-27-2007 11:46 AM
A axis direction change? nervis1 Fadal 18 10-27-2006 11:49 AM
HOW:Line Direction change for MANY lines rherman BobCad-Cam 7 09-20-2006 04:43 PM
How cutting direction change freesman BobCad-Cam 6 07-28-2006 04:02 PM
