Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 09-19-2007, 03:19 PM
flyman219 is on a distinguished road
Lathe tool holder?
Here I am again with another beginner question. I have got my HF 8x12 on the bench and running now and noticed the tool holders that came with the used machine are to big for the square cutter rest. My rest can take about 3/8-1/2" and I was wondering if I could just grind down the top side of the 1/4" tool holder to 1/2". Or, would I be better off just getting some indexable 3/8" cutting tools and not bother with the tool holder. I'm looking at the 5 piece 3/8" set that Littlemachineshop has for about $33. I also got a quickchange tool post with the lathe that will accept the 3/8" cutter bits. Thanks for your time
Mike
Old 09-19-2007, 05:12 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
Cutting tools are expendable. I do whatever I need to do - especially to the shank of the tool to allow them to work in the equipment. I have milled the shanks of insert tooling to allow them to fit into the holder numerous times.
I have even cut the insert end of an indexable holder, milled in an angle and welded it back to the shank to create a more positive rake from an insert that was more neutral than I cared for.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 09-19-2007, 06:06 PM
jrrdw's Avatar
jrrdw is on a distinguished road
I got the HF 8X12 also. I got myself 15, 5/16ths HSS cutting bits from Enco, model number: 383-5320. I grind about half off the shank, then a little off of another one and stack them on top of each other and clamp the down. My lathe came with a 4 post bit holder, i like it! I've allready ground a few different shaped bits, one for o-ring grooves, one for parting/facing/left angle/right angle. I even went to the hardware store and bought a 3/8ths" X 12"s long piece of steel stock and ground one corner off 5"s long, then down the left side for part clearance. I use it to trim out/true sealing faces on pneumatic valves. It's funny looking to see a foot long cutting bit on my lathe.
Make sure you clean my wrench before you put it back into my toolbox.
Old 09-19-2007, 11:57 PM
Thanks for the help, I'm going to grind down the tool holder so it will fit in the tool rest. Next question, the tool holder has the 1/4" bit set in it at a angle rather than horizontal to the work. Is there any threads on the forum that shows what kinds of angles are needed to sharpen the bit. I've seen the angles for the bits that mount dirtectly in the tool rest but not with a bit in a tool holder, left, right, straight etc.
Mike
Old 09-20-2007, 02:47 AM
in2steam is on a distinguished road
Mike
You know you can buy HSS, and its the right size already, although may need to shim it up depending upon your grinding skills.
chris
Old 09-21-2007, 07:24 AM
jrrdw's Avatar
Mike
I would sharpen the bits the same way no matter what tool holder your useing. When it comes to shaped cuts, grind the bits acordingly.
I like this smily
Old 09-21-2007, 07:42 AM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
Here is a little image depicting the various types of lathe tool bits, and their model numbers.
I agree, I make my own tool bits, and tool holders to suit the situations for the parts I'm making. Not all tooling is the same, as different materials require different tool geometry. You need to learn the difference between Positive, Negative, and Neutral Rake. As crystalline materials like brass & bronze require a positive rake, where copper & soft aluminum use a negative rake.
Tools with a sharp point will leave a rough finish, and a slight radius will improve the finish and allow for faster federates. THere are several books available such as Machine Tool Technology ISBN 0-02-671570-8 that cover lathe tool geometry in great detail!
Widgit
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Km-3P Tool holder woodr004 HURCO 1 09-17-2007 09:24 AM
tool post holder omegaghost General Metalwork Discussion 1 05-07-2007 08:43 PM
Live Tool Holder JerryH Fanuc 1 02-12-2006 06:56 AM
tool holder corrie DIY-CNC Router Table Machines 2 07-23-2004 05:04 PM
tool holder types bob1371 General Metal Working Machines 0 04-03-2004 09:02 PM
