Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 09-19-2007, 08:02 AM
Runner4404spd is on a distinguished road
turning 1/4-20 internal thread
does any one make a single point threading tool to turn a 1/4-20 thread on an internal surface? it would be ideal if it was a carbide insert tool.
Old 09-19-2007, 08:47 AM
900steve is on a distinguished road
how about this, but it's not an insert based tool:
http://www.littlemachineshop.com/pro...895&category=8
is tapping the thread not an option?
Old 09-19-2007, 09:08 AM
tapping the part would be an option, but i have to make 500 of these so i'd like to automate it as much as possible. i'm running mach 3 on my lathe and i don't know if it has a G code to run a tap.
Old 09-20-2007, 02:43 AM
in2steam is on a distinguished road
wear on a single point will be hard to control, you would be better off tapping, either with a tapping head or gain control of the spindle. At 500 pcs you will be changing taps or tools either way.
chris
5"-4un Internal Thread Specifications SheldonB Mechanical Calculations/Engineering Design 2 05-12-2007 03:54 AM
Method to internal/external thread ? PeteGallo General CAM Discussion 6 04-03-2007 10:50 AM
Internal Thread Grinders Zumba General Metal Working Machines 4 03-03-2007 09:28 AM
Turning Internal(Figure 8) oil grooves on new Mazak HarleyRyder General Metalwork Discussion 2 04-04-2006 07:53 PM
turning thread Q Shizzlemah AjaxCNC Control Products 0 02-25-2006 03:34 PM
