Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 09-05-2007, 08:04 PM
quick toy is on a distinguished road
Question Proper diameter drill rod or bar stock for threading?
I have a question about threading.
I'm running into some problems during threading. I want to make some 3/4 - 16 stubs. Should I be using .750 drill rod or .740 bar? I noticed that with the drill rod I end up overcutting the threads to get it to work.
Is there a chart or formula I should be using, or is this just novice operator error?
Thanks,
Paul
Old 09-05-2007, 08:26 PM
You will find this sort of thing in Machinery's Handbook but if it is a non-critical application going a bit below nominal and getting a flat crest on your thread is probably okay. I would use about 98% of the nominal diameter.
Your choice of drill rod I would query; it can be a pain to get a good finish in the annealed form. If strength is not an issue use leaded steel, 1018 or 1045 if you do need something stronger.
Old 09-05-2007, 08:49 PM
Thanks Geof
Paul
Old 09-06-2007, 12:31 AM
in2steam is on a distinguished road
Thanks,
Paul
Are you using HSS or crabide? carbide tends to bit into drill rod a little more and results in that problem, as sugested try 12L series instead.
chris
Old 09-06-2007, 09:34 AM
HSS
Thanks for your input.
Paul
Old 11-29-2007, 08:43 PM
imfamous_one is on a distinguished road
for threading you should cut the major diameter .005" smaller than the thread size, so for 3/4 16 .745" would be fine. .740" wouldn't make too much difference as long as you check the thread with a nut to make sure you don't cut too deep and make the thread sloppy. Oh and don't use drill rod... that stuff is hardened and will be super hard even to face.... let alone threading. Just use regular cold rolled. If strength is not as high a concern C12 has high lead content and machines really easy, and leaves a good finish.
Old 12-02-2007, 07:34 PM
jhowelb is an unknown quantity at this point
Here is a chart that may be of interest.
Name:	thrd pitch sizea.jpg‎
What type of drill rod for easy threading using die? ngr1 General Metalwork Discussion 10 12-14-2010 05:03 AM
Indexable drill for 1.00" diameter holes Fudd General Metal Working Machines 12 07-28-2008 06:57 AM
Q: Drill diameter for reamed holes. Deviant General Metalwork Discussion 15 06-12-2008 12:45 PM
Looking for a source or 1/2" diameter 8" length boring profiling and threading bars Green0 CNC Tooling 1 01-04-2007 10:46 PM
Drill Rod Diameter Recommendations grempel1 CNC Wire Foam Cutter Machines 6 11-19-2004 10:28 AM
