Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 08-26-2007, 02:16 AM
Gold Member
heilcnc is on a distinguished road
Question cnc lathe software
i asked before about software for my 7x12 cnced lathe i use turbocnc now but it has many bugs and is not being updated i use cnc zeus on my mill love it have no problems i realy do not want to go the windows way with mach3 but it looks like my only thing left i need threading tried emc2 this weekend got it going but hard to set up and does not support the g codes use just not happy with it like the dos based zeus any help??? thanks
Old 08-26-2007, 10:36 AM
John3 is on a distinguished road
No windoz
Originally Posted by heilcnc View Post
i realy do not want to go the windows way ....
I'd sure agree with that sentiment.
Have you looked at CNCpro? There seems to be support for it and the source code is available !!!!!
Check out:
http://www.crankymachinist.com/cncpro/
http://cnczone.com/forums/showthread.php?t=29711
I'm thinking of using this for my next project.
John
Old 08-27-2007, 01:59 AM
in2steam is on a distinguished road
Sounds like you are trying harder to avoid windows then the effort you would put forth to deal with the odd off bug with it. If this is idealistic did you forget that DOS is from microsoft also? If its old hardware its time to save money. If you just don't like windows(I am not big fan myself) sometimes you have to bite the bullet and deal with it, I hate taxes just like anyone else still pay them though.
I have cnc plotter cutters at work that run 24/7 with no problems in a xp based software, the only problems we get are the ones from the software that the machine uses not xp. At home XP gives me no problems other then a rare problem with explorer which I don't use to browse anyway.
chris
Old 08-27-2007, 05:18 PM
acondit's Avatar
acondit is on a distinguished road
What gcodes does emc2 not support that you need for the lathe?
Alan
http://www.alansmachineworks.com
Old 08-27-2007, 06:05 PM
DOS v. Windoz
IMO, staying with DOS makes sense on several levels......
1. DOS is a much better (launching) environment for real time control programs. A program can take full control of the PC and its hardware.
That means better more accurate time slice processing.
2. Windoz has a vast amount of software overhead that gets in the way of clean machine control.
3. My guess is that your plotter doesn't have its servo/stepper motors controlled by windoz, Instead windoz is dumping higher level commands to the plotter and there is one/several other real time processors in side the plotter doing what is being proposed by the DOS controller.
4. Windoz WILL crash more than DOS. If for no other reason than there is much more code. At any given failure rate per lines of code, per numbers of routines, per modules executed windoz has more chances to crap out.
Also, the core DOS code has been around a very long time has been rung out many times over. Windoz on the other hand still has uncharted spyware hooks that Bill probably doesn't even know about (or will admit to).
We use windoz on a large number of computers. And based on how often those freeze or have problems, I would not want that for a machine in the middle of a time consuming or expensive part.
my $.02
John
chris
Old 08-28-2007, 12:39 AM
Ha,
You hit my buttons on the mark, but on the same tolken the machines that I run still rely on the code to be correct, its been my exeperience that only hardware and operator error have caused problems, not windows or the underlying system these are networked with roughly 400 others. These machines also intergrate a visual positioning system so far more overhead then a normal mach machine would have.
Thats not say you could not get a plc to run the lathe and have mach run it, again not a perfect system and I don't always like it. I do understand the benefits to DOS, and I know windows isnt perfect, but on the same hand if you don't expose the computer to the effects of having a bunch useless crap on it then your possiblites of crashing are greatly reduced, windows XP in of itself is a good program its all the other stuff that great reduces its ablity and increases its overhead(this being brought to my attention after having to do a fresh install becuase of a hardware faillure on my own PC). If you are going to be worried about running a long or complicated part its best to not even have the computer used other then the purpose of driving the machine and related software. The true fact is the machine cannot react as fast as windows(on a newer machine) can in a given time frame-assuming all is well with both. I am old enough to have used DOS enough to know is not exactly perfect either, however I would agree that its far and away more so then XP as an OS.
chris
Old 08-28-2007, 05:36 PM
cjdavis618 is on a distinguished road
While I am a new poster here, this topic is an old one for me. I am a network engineer by profession and that is as far as I will go for background this discussion.
The question for the original poster should be is the cost with windows the problem or is it the hardware requirements?
I can tell you first hand that most problems with windows usually happens to be the applications that run within it are poorly written, or incompatible hardware that someone finds on a shelf that they want to work. Usually it is for some gadget or gizmo that serves them no real purpose. Just turn off the software you don't need and don't install software you know nothing about. Really, software programmers are no different than anyone else. They create things they need or want and have the choice to use extraordinary detail, or make crap. They to sometimes have to use crappy tools they are given and then some use good proven software to create quality product.
Really, can any of you honestly say that you have put extreme detail into everything you made? Never made anything in haste? Honestly?? No mistakes either I bet. lol
I have several racks of servers that I maintain (Or get paid to anyway, they are self sufficient unless hardware problems occur.) I have a mix of SCO unix, Windows 2000, NT 2003 and even a few Linux servers that I never have issues with. I love Linux, I have no problem with MS and Unix is yesterday. Bluntly put, anyone that is capable of running Dos is over qualified to fix anything with XP. If they choose not to, it had better be for money reasons or they are complacent in ignorance.
If you want a stable PC, stop running to the bargain bin at your online or local computer store to buy your parts and do your homework. There is a reason for the "HCL" (If you don't know what that stands for, find another hobby). Get a computer that has all components from the HCL, load windows, use windows built in drivers and run it. If you want extra assurance, get an old server off of ebay and run your CNC on that. In fact, hit me up and I might sell you some that have proven themselves for just such a task.
As for Dos as a whole, come on. I'm not even going to waste my time why that would be a asinine step backwards. If money is the object, get a copy of ubuntu or something and figure it out. You will be much better off.
If money isn't the problem, well.. good luck.
PS. All those extra lines of code that was put into Ms products, were asked for by customers and R and D. It is really easy to blame old Bill with his billions of dollars. All those "hooks" that were mentioned are called "Exploits". Although we have a few choice names for the people that abuse them, we still correct them as they are found.
Old 08-28-2007, 08:01 PM
Gold Member
i do not use junk on my machines!!!!!!!! windows good for every thing but cnc control i use cnczeus never crashes i did try mach3 but did not get the preformance that i got with cnczeus a dos based system for mills tried emc2 but i would like a easy setup i did get it to work on my mill but took hours
Old 08-28-2007, 08:23 PM
Bubba's Avatar
Bubba is on a distinguished road
My "Personal Opinion" of Windows is there is to much "JUNK" running in the background to make it useful for a Real Time System.
For this, I like DOS and because my controller box does nothing but run the machine, this makes me happy.
I do not have to jump through hoops to make it run real time and I am not in the shop to sure the net or anything else. Just make the machine do what I want it to.
I do not want or need some fancy GUI to make parts. Nor do I need a mouse to make things happen. Just a nice stable keyboard and minimal graphics on the screen. All parts are run through a simulator to be sure they will look like what I want and if the powe doesn't fail, they have.
On top of that, I can run "junk box" computers and it gets the job done!
Art
Old 08-28-2007, 10:14 PM
If that works for you, then great. You said yourself that there were bugs in the program you were using. This will be no different with any program. I have found some in mach3 already and havn't even got my CNC installed.
Look, I'm not bashing anyone individually. I am sick of the Linux VS windows debate. And frankly it is refreshing to see DOS being the topic for a change. I have been in this business since before DOS 2 (As a hobby even longer) and have been around the block a couple of times since.
Most of the stuff that XP and other MS OSes installs by default can be removed. There are XP "lite" options that reduce the number of added crap that MS puts out for the average user.
Regardless of whether you like DOS or not, it is NOT capable of using the majority of hardware on the market today to it's full potential. Yes, you will get basic functions, but the applications and the command.com itself cannot use the upper memory and CPU registers on most processors since the late 1990s. Therefore, Real time and Virtual timing become a blurred vision. It seems to me like buying a half million $ Ferrari and ordering it with a 3 cylinder GEO metro engine. I'm sorry it just makes no sense to me.
If you have a separate PC to draw and code with, then why not. But that wasn't stated in the original question. I prefer one station take care of all of the needs in the shop when it comes to CNC. JMHO
  #11   Ban this user!
Old 08-28-2007, 10:40 PM
Originally Posted by cjdavis618 View Post
While I am a new poster here.....
I have several racks of servers that I maintain (Or get paid to anyway, they are self sufficient unless hardware problems occur.) I have a mix of SCO unix, Windows 2000, NT 2003 and even a few Linux servers that I never have issues with.....
Real Time Controllers and Enterprise servers are two completely different applications for computers. It is just not reasonable to think that what hardware and what software works the best for one, will work the best for the other. There are different performance, interface, memory, diagnostic, etc, specifications for each application.
HCL??? "Hardware Control Language" or "Hardware Compatibility List", not sure what hobby you've found.
Yeah right, an old server with dried out electrolytic capacitors, corroded connector contacts, worn out drive and fan bearings and that's been sucking in dust for the last 5 years is going to be more reliable than new low cost PC hardware?
Its even more asinine to think that windows can provide the same quality platform for a high performance real time controller with respect to the issues that matter. There will be tons more phase jitter (which matters in real time control) from windows maintaining its background tasks and processing things like mouse port interrupts.
The reason DOS makes a lot of sense for this type of application, is that there isn't much to it as an OS. It provides the basic bootup, file and interface functions, Then the controller software can take FULL control of ALL hardware and software resources. Just not possible in windows.
For a totally different perspective on this, the Book "Undocumented PC" makes for very interesting reading.
At ANY given professional or knowledge level, the chances of getting burned or suffering a problem with OS "Exploits" is infinitely less in a DOS environment as compared to a windoz environment.
John
  #12   Ban this user!
Old 08-29-2007, 12:07 AM
HCL stands for Hardware Compatibility List. Funny though that you should make my point for me. Hardware Control Language was written by IBM for the AS400 platform. lol Still a Computer system in its own right.
As far as not being possible for hardware to be controlled in windows. Depends on which windows. There were 5 (well known) versions of windows that gave you direct access to the hardware. They all were based on a Dos Platform. Care to guess which ones?
What did you say you were running your CNC from? Mac maybe?
Just because I have extra servers doesn't mean they are old. Just means we upgraded. Never said anything about old.
As for the Exploits, you are correct. Provided the system is non networked, no access to any drive system other than HDD and a single operator. In those circumstances, I would put any XP system up to the same standard. You can't compare any other windows platform to a dos platform. That is comparing apples to oranges. They were designed and used for different things.
It's interesting that you bring that book up. The information contained in there was pivotal for the development of Windows. Hence Plug and Play and hardware detection through IO device mapping.
Best cnc lathe software Drew General CNC (Mill and Lathe) Control Software (NC) 3 02-04-2007 03:07 PM
cam software?? for lathe chrisw765 Mini Lathe 5 10-13-2006 06:29 AM
need cam software for cnc lathe. rhino CamSoft Products 0 09-13-2006 03:51 AM
CNC Lathe Software mikedb1972 G-Code Programing 6 06-20-2006 06:50 AM
Looking for lathe CAM software kong General CAM Discussion 2 04-29-2004 08:26 AM
