Page 1 of 2 12 LastLast
Results 1 to 12 of 21
Thread: Parts source for 9X20 - got one?
    Gold Member mxtras's Avatar
    May 2005
    Arrow Parts source for 9X20 - got one?
    I thought I had a source tucked away but after an exhaustive search of my links as well as this forum, I am unable to locate a source for repair parts for the 9X20 HF or Jet lathe. I am a bit suprised because I seem to recall a link in this forum but a search for "parts" or "repair parts" turns up nothing relevant.
    Can anyone help a brutha out with a repair parts source? I desperately need a spindle drive belt or three...
    Thanks!
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Jun 2005
    i get my belts from www.Wholesaletool.com
    May 2005
    It appears as though that site has been hacked (?). I get a page that states something to the effect of:
    "Products purchased will not be delivered nor will the customer be billed. Any information seen on these products is to be treated as fictional."
    Just a tad unusual for a commerce site.
    Scott
    Registered acondit's Avatar
    Apr 2005
    Scott,
    I bought my belts at a local bearing supply house for about 1/2 of what I could find them anywhere on the web. You might see if you could have such luck. It also meant no shipping charges.
    Alan
    Mar 2006
    Ebatmus.com carries the polyflex belts. I have ordered from them several times and they have good prices and excellent service. A 5m710 belt goes for $ 7.51 and a 5m730 goes for $7.73
    Grizzly has every mechanical replacement part for the g4000 9x20 which is the same as the HF 9x20.
    Steve
    Feb 2007
    Check your local parts, belts and bearing stores. The belt is made by Gates
    Here's were I bought my belts, very fast shipping! Buy a few at a time, you'll need them. I can't believe they make these belts so small, I guess this is another money maker on the 9 x 20 HF.
    http://www.evbelts.com/advanced_sear...o=&dfrom=&dto=
    Feb 2006
    us
    Here http://wttool.com/
    Wholesale Tool Co. - Industrial Supply
    and here http://www.grizzly.com/products/G4000
    G4000 9" x 19" Bench Lathe
    Apr 2005
    Quote Originally Posted by twocik View Post
    Twocik,
    I have had my lathe for 7 years and have never had to replace that belt. I have had to replace the toothed belt though. Maybe I should knock on wood, but most of the people that I have talked to said that the small belt is way stronger than the toothed belt. I believe that it is urethane instead of rubber.
    Alan
    May 2005
    Quote Originally Posted by S_J_H View Post
    Steve
    This is where I ordered the 5M730 from (www.Ebatmus.com). I ordered three of them on Monday, had them Wednesday. Only problem is that it appears I need the 5M710. The 5M730 is too long, but I was able to manipulate a tensioner and run the job, so I am off the hook for now.
    The problem now is that I have three of the longer belts and have no use for them!
    Does the Harbor Freight 9X20 take a 5M710?
    The Grizzly lathe manual shows a 5M730 and I thought they were identical machines to the HF9X20. I guess there are some differences in their pulley sizes or maybe its the motor base.
    Anyway - it looks like I need a 5M710 for the Harbor Freight 9X20 and I have three 5M730s.
    Thanks for the links and the help, guys!
    Scott
    Registered SScnc's Avatar
    Jun 2008
    Quote Originally Posted by mxtras View Post
    I finally broke the belt on my HF 9x20 lathe. I contacted ebatmus for the 5M730 and they are backordered, then I found this post.
    Can someone tell me which one the HF actually requires, 5M730 or 5M710 ?
    I appreciate any help,
    Steve
    Registered Crevice Reamer's Avatar
    Mar 2008
    HF 9 x 20 Manual:
    http://www.harborfreight.com/manuals...5999/45861.pdf
    HF Parts: 1-800-444-3353
    It takes about 2 months to get them.
    CR.
    Jun 2008
    Thanks CR but I'd already been down that road, and several others. HF tech line could only give the info in inches and it converted into ~800mm.
    I didn't want to wait any longer or pay shipping that amounted to the same price as the belt so I went to Carquest this morning and got a 3/8" x 28" standard V-belt. I welded up a simple jig with guide rails 3/8" apart with a utility knife razor blade sticking up through a slot in the center and locked in place underneath with set screws. Mounted the jig in a vice.
    I set the 3/8" belt into the jig and pulled it through and it very neatly sliced the belt exactly in half. I touched it up on my bench belt sander to give a slight V to the cut side and installed it on the 9x20.
    It works just fine, smooth and quiet and I ran it all afternoon turning 2" cold rolled steel down for Tormach style mill tool holders. The belt didn't even get hot, no problems. And it only cost $12.00 and got two from one belt.
    Anyway, I'm happy !
  • Page 1 of 2 12 LastLast
    1. What's your favorite used machinery/parts source?
      By ralph@nes in forum General Metalwork Discussion
      Last Post: 06-26-2007, 09:28 AM
    2. Can anyone help with a parts source?
      By PoppaBear10 in forum Bridgeport and Hardinge Mills
      Last Post: 08-18-2006, 06:26 PM
    3. Looking for a source for HPI Savage RC parts
      By nosplinters in forum Parts for Radio Control Models
      Last Post: 07-25-2006, 02:44 AM
    4. 9X20 Replacement Parts
      By kdoney in forum Mini Lathe
      Last Post: 04-05-2006, 10:35 PM
    5. Open Source Parts Library
      By Rance in forum Alibre Design
      Last Post: 12-13-2005, 09:44 AM
