Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 08-10-2007, 10:13 PM
bnalls is on a distinguished road
Sherline lathe question
Hi everybody. Quick question about my Sherline lathe. The Slide screw insert on the lathe table requires the motor to be turned many times before it changes direction. Is this an understood design characteristic or is this a problem w/ my lathe. It would seem like an incredible amount of backlash, but it looks like there's no way to combat it so I figured I'd reach out and ask. Thanks for any and all responses.
Brian
Old 08-13-2007, 10:55 AM
lfbrown is on a distinguished road
Sherline Backlash
Hi Brian,
Sherline is legendary for backlash. I assume you're using the power feed, hence your reference to the motor turning.
I don't have the motor but there is always .25+mm backlash in the saddlenut. Even with a brand new saddlenut I routinely get .12mm which quickly wears out to the .25mm mentioned.
Sherline now offers, however, a leadscrew backlash lock. See the following link for more info and a part number. I bought one for my mill but haven't installed it yet so I can't tell you how well it works.
http://www.sherline.com/4417Zpg.htm
Les Brown
Old 08-13-2007, 03:41 PM
zephyr9900's Avatar
zephyr9900 is on a distinguished road
Hi Brian, something is definitely out of adjustment with your lathe. It should be possible to get .003-.005" (.08-.12mm) backlash with the stock lathe.
My lathe is a stock 4400 with CNC, and I can regularly turn parts to .001-.002" tolerance (backlash measured and compensated in TurboCNC.) If your lathe is CNC, are you sure that the leadscrew support bearings are adjusted with no play?
Best regards,
Randy
Last edited by zephyr9900; 08-13-2007 at 06:35 PM. Reason: Junk about backlash adjustment removed. Thinking about my mill...idiot me.
Old 08-14-2007, 09:44 PM
Thanks for the replies! The table was indeed not tightened towards the center of the screws is a nut apparently but I have yet to fix it. Thanks for the responses!
Brian
Sherline Cnc 4400 Lathe STIELJTES Mini Lathe 2 08-09-2009 07:59 AM
Sherline, Grizzly, Harbor Freight Sieg lathe twocik Mini Lathe 35 06-20-2007 02:24 PM
Sherline 4000 Lathe sleepy23 Mini Lathe 1 11-09-2005 04:44 PM
Sherline Mill and Lathe on Ebay Halfnutz Benchtop Machines 2 05-15-2005 09:10 PM
Choosing a Sherline mill or lathe kdoney Benchtop Machines 0 04-19-2003 11:36 AM
