| Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here. |
i am looking into cncing a small lathe &i would like to be able to do threads that it does not have gears for.i was thinking of 4 axis 1for left to right, 1 for the cross travel, & 1for the compound travel. all that i think i can do with no problems. my ? is if i am not using gears to cut threads can i use steppers on those 3 axis & a dc motor with an encoder on it to turn the spindle, or would i have to use a servo for the spindle? which ever i have to use i would also have a tach on the spindle.so can i make this work with one of these motors for the spindle & steppers for the other 3? thanks in advance for any info i may receive back. greg |
| It should be doable, check out MACH or DESKCNC for affordable step/direction stepper drive scenarios and, by all means, do a "lathe retrofit" search on the 'Zone. The retrofitting of a lathe is a bit more challenging than that of a mill. For non-mechanical linking of the spindle to the lead screw, you will need a VERY accurate timing scheme in order to do threading. This is one of the prime challenges of lathe retrofitting. Although the "lathe retrofit" thread that I initiated some time ago is for a lathe a bit larger than what you want to do, the exact same problems/concerns will have to be addressed regarding timing, driving and steppers vs servos. BTW, do a "stepper versus servo" thread search - the info there will answer any questions you may have about which you should use and/or why - if it doesn't answer the question, it will at least provide tech input so you can make more informed decisions. |
| The Mach3 Turn manual has some info about an index pulse for a lathe spindle. I think that most mach3 users doing threading use a single index pulse to detect spindle rpm, and Mach3 adjusts the other axis to accomodate the spindle speed. http://www.artsoftcontrols.com/docum...Using3Turn.pdf
It is really easier than you have outlined in your question. I cnc'ed my lathe about a year ago, all you need is 2 steppers. One for you z axis, and one for your x. The compound is eliminated, you only use the cross-slide. The software can create the angles you need by incrementing the z & x. As far as threading goes all you need is a spindle index signal. I used an optical pickup with a slotted wheel. The software uses this to determine speed and the position of your spindle. I can cut any pitch, metric, english or my own custom pitch. Along with the steppers you will need driver cards to drive the steppers and a breakout board to interface to your pc. Arnie |
| Im in the process of reliving my thread on cnc'ing a mini lathe Sieg C3 mini lathe - My shot at a CNC conversion Maybe you can find some inspiration there, a lot have happend since my last post, but i lost my digicam along the way |
| Converting my Engine Lathe to an 8-Station Turret Lathe! | widgitmaster | General Metal Working Machines | 93 | 10-31-2011 04:27 AM |
| cinturn lathe with an acramatic lathe | PETE1968 | Mastercam | 18 | 10-15-2008 09:37 PM |
| Lathe Comparison - Best small lathe for CNC | acondit | Mini Lathe | 48 | 03-23-2006 08:10 PM |
| Anyone have a mini cnc lathe or medium sized cnc lathe | nymachinist | Mini Lathe | 6 | 01-23-2006 09:36 PM |
| New Micro lathe built by me (my second lathe) | Stevie | General Metal Working Machines | 15 | 11-03-2004 04:56 AM |
