| Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here. |
| 7x12 Mini Lathe Anti-Backlash nut. Has anyone made one of these, or know of a website that provides them? I've tore the machine down to the last screw and reassembled with fresh oil/grease and tighten all the grub screws and handles. The carriage is very solid now. With two problems. The cross slide handle has about half a turn play. I don't think there is any more adjustment that I can do with the base hardware to improve this. I think the next option is to mount some type of anti backlash nut. The compound has a little play, but not quite as much. I'd like to get these down to bare minimal. I'm not sure what the best solution would be. Mill/thread a piece of delrin/cutting board? Mill/thread a peice of brass slot it and add an expansion grub screw? Another option would be use some type of ball screw, but I think that would involve making a new saddle. Second problem. The half nuts have a small amount of play. I'm going to try to adjust this out. But I'm not sure what a normal amount of play would be. I'm not even sure if this is an issue, as you don't normally have a lot of forward/back movement with halfnuts. Any info/help would be great. Thanks |
| Wow half a turn of the handle; that’s not good. I have close to 0.025mm (0.000984249”) of backlash on mine. Have you see this http://www.mini-lathe.com/Mini_lathe....htm#xbacklash . John |
| No I hadn't seen that area of the website. I crawled all over the site before I bought the lathe and never saw it. I'll give the adjustments a go. Hopefully the backlash will clean up. It it's current state, it is highly frustrating to deal with. Thanks for the reply. *edit* I just went out and attempted to move the cross slide back and forth. I have no detectable play. I'm going to put a indicator on it, for a better view. I have roughly 1/4 turn in the handle. If I'm doing the math correctly, that's .2mm. ((8*0.025mm)). Going to try the instructions now. |
| Lathe antibacklash nut I am converting an 11 x 26 lathe to CNC and am concerned about excessive backlash so I made the antibacklash nut shown in the pictures. The block and nut are made from 420 SS and the screw a LH 7/16 x 20 made from a piece of drill rod. The spring was purchased fron MSC # 36099G. The screw is a LH 7/16 x 20. I have not tested it as of yet but I feel confident that it will work. regards, John Kelly |
Nice job; did you do any calculations to workout what spring to use? Would you mind posting here after you have tested it? Regards, John |
| antibacklash nut I have purchased a few different springs and the one that feels the best so far is about an 8 lb. spring. I will keep all posted as I test the system, my biggest concern is going to be wear on the nuts but time will tell. regards, John Kelly |
| I adjusted the 3 screws and took out 99% of the backlash. I never realized that those screws were for that purpose. The problem now is that the screw is very hard to turn. I'll have to keep messing with it til I get a happy medium. I didn't see any type of adjustment for the compound. It has a little bit of backlash, but nowhere near that was on the cross slide. Thanks for the link. It helped alot. |
| Played in the shop for a bit tonight. Was able to turn down a piece with .0001mm of what I was looking for. It's like a brand new toy. *grins* Played around with the screws for a while, finally found a good setting that took away the backlash and still allowed me to turn it with very little effort. |
| 4 or 5" 4-jaw chuck for 7x12 mini lathe. | Deviant | Mini Lathe | 7 | 03-07-2008 03:44 AM |
| anti backlash nut? | sixpence | DIY-CNC Router Table Machines | 13 | 07-18-2007 02:51 PM |
| Anti Backlash | sala84 | JGRO Router Table Design | 3 | 11-05-2006 09:04 AM |
| Are those anti-backlash | CnC_BoY | Linear and Rotary Motion | 6 | 03-20-2006 10:58 PM |
| anti backlash nut | hpghost | Linear and Rotary Motion | 3 | 05-15-2005 09:16 PM |
