| Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here. |
I am in a market for a high quality precision mini lathe and my budget is $1000. I am leaning heavily toward the Proxxon PD 230/E. The other one I can think of is the LATHEMASTER 8x14. I considered the Sherline but it is mostly all aluminum. I like the Proxxon because I can put in my small hobby room. The Lathemaster would most likely end up in the garage. I have read a lot of good reviews on the Lathemaster. The parts I will be turning are aluminum mostly in 1-2 diameter which are for my model airplane hobby. I have yet to find any review of the Proxxon on the web. Does anyone have any experience with the Proxxon? Is there any alternative in this size? Thanks. |
| The Proxxon seems to be smaller than even the HF 7x10. My opinion is that the accuracy is not really in the lathe - it's in the operator. When I first got my 7x12, holding ±0.005 made me happy. Now I shoot for tenths in stainless on the same exact lathe! The only different is time. For $1000, you could be set up with both a 7x12 and a SIEG X1 micro-mill including a decent amout of tooling. Both are light enough to move alone. With the Proxxon, your still going to need to invest in tooling. Aaron |
| I am sure there is difference between a $1000 German made lathe vs. $300 Chinese. From everything I read, the 7x12 are a “kit” which must be reworked to make anything decent. Operator aside, I am looking for a lathe that is high quality and ready to go right out of the box. Thanks Samim |
| The proxon is a smaller lathe, more along the lines of a taig or sherline. At 30lbs vs. 90lbs of the 7 x 10. Can't speek to the quality. You might look at the Grizzly 7 x 12 or the microlux 7 x 14 which are supposedly a little better finished than the HF. http://www.ares-server.com/Ares/Ares...oduct&ID=82710 The microlux also has a tach. My HF 7 x 10 does the job, but I can't say it's without some frustration. The proxon also has metric dials, the mircrolux has decimal. As far as RC parts, which is also why I got the 7 x 10, it hasn't stopped me from anything I wanted to do. My biggest beef with my 7 x 10 is I wish I had 4 more inches of clearance, and I should spend the money on a 4 jaw chuck, and quick change tool post. The other thing you will gain with one of the 7 x (10,12,14) is a lot of support of tooling that I don't think you will find with the proxxon.
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
| I've personally been impressed with the Microlux lathe. Smooth, and fairly rigid for it's size. I like the camlock tailstock as well. It is surprising at how deep a cut I can make in aluminum. Amazing little machines. We will have a CNC version of this in the next few months.
__________________ Direction, Commitment, Follow Through |
| If you really want small high quality check this one out. They also come up second hand from time to time. http://www.cowells.com/ In the USA: Cowells USA Post Office Box 843 Richmond, KY 40476-0843 (606) 624-9269, (606) 625-1191 (FAX) Regards Phil
| Have you looked at: Emco, and Prazi (Hobbymat). Phil
Just because it is German made does not automatically mean high quality. Look at the economy difference, once the labor costs are equalized I wouldn't be surprised if they come out to be almost equal in cost. Aaron |
#10
| i'd be leary turning 1 or even 2" material on these small lathes. the 7x10 and 8x14s are ok but i would really lean towards getting a 9x20. they aren't that bad and need similar tweaks to a 7x10. in the long run the 9x20 will be more versatile and they can be had for about $700 from harbor frieght. |
#11
If I had to do over again, I would still by a 7 X and put the extra money into tweeks and tools. I just wish HF or somebody would come up with a 7 x 14 in with a $400 price tag. I keep debating on just buying little machine shops 14" mod kit.
#12
| The 8x14 is just the 9x30 with less between centers. Either lathe is dramatically more rigid than the smaller lathes being discussed, and are quite a bit more rigid than a 9x20 too. In fact, unless you step up to a 12x30 or so, they're probably the most rigid lathes out there. Their chief disadvantage is no quickchange gearbox for threading--you're stuck using change gears. That's hardly a biggie for most folks. I would go for the 8x14. BTW, they're available from more places than Lathemaster, I believe Harbor Freight even has one. I can't personally see much advantage in the really small lathes when you could get an 8x14. Best, BW |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
