Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 09-09-2006, 12:55 AM
Masood is on a distinguished road
Takisawa Tw-20, CNC lathe
Hello,
i am new this Forum...
i am use Takisawa Tw-20, CNC lathe, (Takisawa Fanuc) panal..
i have a problem to link machine to Rs232..
i make a cable Machine side 25pin PC side 9pin....
i use a Terminal for sanding a program....
My problem is which Botton i press the machine, i am press Memory botton bit it's not responding..
kindly help me...
i am run this machine for Automatic...i am not found a Tape mode in this machine...
Masood
Old 09-10-2006, 01:38 PM
Trapper14 is on a distinguished road
what software are you using to send the program? sometimes you have to have specific baud rates and such in order for the program to send properly.
Old 09-10-2006, 02:11 PM
Al_The_Man's Avatar
In Memory and push Read, the LSK should flash in the bottom RH corner.
Old 09-11-2006, 02:41 AM
thanks for reply me...
i am trying to guaid link...but not sucess full....
(1st try)... i Press Memory Button, and press Program, and press (Oprt) and press (Read) and Press (Exec), shom me 086 BP/S Alarm...
(2nd try)... Frist i sand Program in Computer..
and press (Read) and press (Exec) and show me flash "LSK"
and i press Start Buttan run machine Move X an Z but Continues Flash "LSK"
and i press pos button not show me Still same Screen Flash "LSK"
machine Detial..
Takisawa
Model : TW-20
Date : 1996
Takisawa (Fanuc)
Old 09-11-2006, 02:45 AM
Same Problem...
machine Detial..
Takisawa
Model : TW-20
Date : 1996
Takisawa (Fanuc)
Old 09-11-2006, 12:12 PM
Al_The_Man's Avatar
Do you know the Fanuc system type i.e. 0, 10,11 20 etc?
BTW I have answered your PM.
Old 09-11-2006, 11:07 PM
ok masood, did you try sending the program while in EDIT? Try that, also make sure you have the computer sending the program first, and then hit READ, EXE and it should recieve it. Also on some controls you have to type in the program number that you are sending over first, on my 16-m fanuc I have to go
EDIT
OPRT (then move one screen)
READ
EXEC
good luck
Sean
Old 09-11-2006, 11:59 PM
Hello Dear...
i am use this cable My Haas CNC milling cable working okay..my software setting is okay..becouse cnc milling machine working good..
this cable and software i use Takisawa cnc lathe...
here is my cable connection..
CNC side (25-pin male) ----- PC side (9-pin female)
pin 1 ---- cable shield
pin 2 -------------------------- pin 2
pin 3 -------------------------- pin 3
pin 5 -------------------------- pin 7
pin 7 -------------------------- pin 5
pins 6 & 8 --------------------- pin 4
here is My Communication software setting..
Baud Rate : 9600
Data Bits : 7
Stop Bits : 1
Parity : Even
Flow Control : Xon/Xoff
this setting i use..and i sand the program machine Alarm
085 : Communication Error..
plz..tell me i am very absad
i am waiting your reply...
Best regrad
Masood
Old 09-12-2006, 11:06 PM
I am at a loss, sorry no idea whats wrong, perhaps this thread should be move to the Fanuc forum? may have a better chance of solving it there.
Sean
Old 09-14-2006, 12:03 AM
Leblond Makino (fanuc OM) Problem
Hello,
i am use Leblond Makino cnc milling. (Fanuc OM) .use manule program..
i am trying to this machine to Auto mode to Pc use Rs232 cable..
kindly tell me which parameter chang this machine to run tape mode..
my Rs232 cable is working other machine cable is okay...
but i am not Understand Makino (fanuc OM) panal...
kindly help me..
Masood
Old 09-14-2006, 08:44 AM
Al_The_Man's Avatar
IIRC it is not only a parameter but an input (switch etc) has to be made into the PMC (machine controller, Ladder).
To enable the drip feed system.
  #12   Ban this user!
Old 09-22-2006, 01:35 AM
Leblond Makino Type RMC 55 (Fanuc OM)..
Hello,
Kindly tell me PMC...what is PMC?
i see my Machine panal...PMC Slat is free No card in this slat...
kindly tell me Which Praameter change this machine
Thanx..
Best regrads
Masood
