Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 08-14-2006, 01:02 PM
Deviant is on a distinguished road
Q: Mini lathe Tailstock Alignment?
Is there any prefered method to getting this aligned?
I finally got around to trying to drill a hole. It looks like the tailstock is around 1/4" off center.
I see a little set screw on the backside of the tailstock. Does this loosen up the tailstock so that I can align it with deadblow hammer?
Or is there a better way?
Old 08-16-2006, 03:00 PM
RotarySMP's Avatar
RotarySMP is on a distinguished road
Hi Deviant,
The Tailstock of the Sieg 7x minilathe is truly aweful.
Rick Kruger posted this excellent site on aligning this POS.
http://warhammer.mcc.virginia.edu/ty...ase/index.html
Here is my take on it:
http://www.wrathall.com/Interests/ma...ent_check4.htm
Good luck.
Regards,
Mark
www.wrathall.com
Old 08-17-2006, 04:37 PM
Ok,
I've decided that my tailstock is a pos.. = P~
Is there anyone that makes a drill chuck that I can mount to my cross slide. The cross slide appears to be "almost" accurate.
I'd prefer to have it on a 3/8" tab so that I could mount it in my quick change tool post.
*grumbles*
Old 08-19-2006, 03:38 AM
RotarySMP's Avatar
I use a Phase II Wedge style QCTP and the set came with a tool holder with Morse 2 female taper, so you can mount a tailstock drill chuck straight in. I can't say I have used it often, as finding center with this is also a PITA:
I just mucked around with the tailstock till I got the thing within a couple of thou of centered (at a medium lock down torque, as this affects center height) and use it.
Regards,
Mark
www.wrathall.com
Old 08-19-2006, 06:06 PM
Trapper14 is on a distinguished road
I would imagine you would need your gibs on your saddle pretty tight so it doesn't tip back when you go into drill?
Old 08-19-2006, 07:25 PM
I don't think the pressure would be much greater than standard turning or using a boring bar.
I'm gonna look into a mt taper for my QC post. That or I'm gonna have to make a new tailstock. This one is too annoying.
The bottom barely touches in some places... I can see light, even with tighten down. additionally, I think that it is moving from side to side on the taper slide, even with the grub screw borderingon stripping out tight.
*grumbles*
