Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 07-06-2006, 05:12 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
Cool Adding a coolant pump to my new lathe
Now this is extreeme!
I wanted to add a coolant pump to my new lathe, so I drilled a 1" dia hole in the center of the chip pan! Then I placed a 5-gallon bucket with a "Little Giant" pump in it under the hole. But when I turned on the pump and let it flood the machinery, i noticed it was puddling in the ends, and not in the middle by the hole!
So I looked at it and scratched my head for a few minutes, then I reached into the bottom drawer of my tool chest, and grabbed my 3-ton Armstrong screw jacks! My idea was to bend the pan so the fluid will run to the middlle and out the hole!
I grabbed a 3/4" block of aluminum, and a 5/8" open end wrench, then proceeded to scratch my knuckels while positioning the jacks under the lathe bed and the aluminum block! This was extreem to to sa the least! I would never have thought I would be bending the chip pan while the lathe was attached!
When I realized the idea was working, I repositioned the jacks to various places along the center of the pan, creating a valley which tapered toward the hole!
When finished, I grabbed my level and re-checked the lathe bed, and it was still dead nuts!
Another day in the life of a Widgitmaster!
Eric
ID:	19638   Click image for larger version
ID:	19639   Click image for larger version
ID:	19640   Click image for larger version
ID:	19642   Click image for larger version
Old 07-06-2006, 06:19 PM
Trapper14 is on a distinguished road
thats pretty slick, well done!
Old 07-06-2006, 06:47 PM
Burn is on a distinguished road
Make sure you're always running the pump with liquid in it- All centrifugal pumps require liquid always to be in the pump body to cool and lubricate the parts...I would use a butterfly valve to limit the amount being sucked in to avoid running it dry.
Old 07-06-2006, 07:07 PM
Gold Member
Cool
I doubt that "Little Giant" pump on a gravity return system is going to burn up, as long as I remember to turn it off!
I bought a neet little knozzle with a valve and a magnetic base from Enco
Now my course knurling tool wil not over heat when knurling 303 SS!
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Old 07-06-2006, 09:34 PM
I have seen it happen before...It isn't fun. In PC watercooling loops, the impeller melted.
Old 07-07-2006, 05:41 PM
Gold Member
Cool
Burn,
I don't think the coolant pump system in my lathe has the same intensity of heat that a CPU chip cooling system puts out!
By adding a coolant pump to my lathe, I can now run at faster sppeds and feeds and make nicer parts! No to mention my hands are free from having to put cutting oil on the part with a brush!
I saw the CPU cooling manifolds you were making, and I think that is the only way to go; whereas, the processors are getting hotter as they make them faster!
Eric
Old 07-07-2006, 08:28 PM
Originally Posted by widgitmaster
Burn,
Eric
Thanks. A lot of time and development has gone into them.
Actually it wasn't the heat generated by the CPU that caused the impeller to melt, it was the heat generated by the pump itself!
Old 07-16-2006, 10:15 PM
Green0 is on a distinguished road
He has a 5 gallon bucket of coolant- HOW the hell is he going to run dry?
Where did you get the pump?
Old 07-16-2006, 10:31 PM
Gold Member
Cool
I got it from Enco!
Model #505-3586
Low Price: $48.36 ea
1-AA LITTLE GIANT PUMPS
GPH: 170 @ 1'
Power Cord Length: 3
Amperage Rating: 1.1
Horsepower: 1/200
Outlet Size (Inch): 1/4
Pressure: 3.0
Material: Aluminum
Manufacturer Part Number: 500000
http://www.use-enco.com/CGI/INPDFF?P...MITEM=505-3586
I bought one for my Bridgeport mill, but that will be another major project!
Eric
Old 07-17-2006, 06:35 AM
All I am saying is be careful!
  #11   Ban this user!
Old 07-18-2006, 01:56 PM
vladdy's Avatar
vladdy is on a distinguished road
I have a couple of the Litthe Giant pumps here, and use one on a homemade parts washer...
the ones I have are internally filled with something similar to varsol, and will run cool without needing a fluid supply to the pump..
I got these from a scrapped restaurant dishwasher, so they may be different than yours..
The reason I had them apart was that the seal between the motor and the pump rotor kind of 'swelled' a bit when I used it to pump carb cleaner, and I had to take it apart to replace the seal..Little Giant didn't want to sell the seal seperately for this mode, but they would rebuild it if I shipped it to them..
local Acklands had a seal that seemd to work ok for Varsol, and I remeber not to pump carb cleaner now...
Running basically 'stalled' overnight didn't hurt the motor itself, by the way..
enjoy..
  #12   Ban this user!
Old 07-18-2006, 04:02 PM
Perp is on a distinguished road
Here is a dumb newbe kinda question. when you run a coolant with your lathe or mill, what keeps the machined steel surfaces of you machine from rusting. is the coolant an oil or maybe like an automotive antifreeze with rust inhibitors in it? When you are done for the day do you have to clean and oil the whole machine or do you just leave it be? thanks, and excuse the hijack please.
Doug
