| Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here. |
| I have been doing a lot of repetitive tasks on my new lathe, so I decided its time to make a nice solid stop to go inside the spindle bore! Last edited by widgitmaster; 06-25-2006 at 12:59 AM. |
| So I grabbed a piece of 2" diameter 1018 steel and turned it to fit the inside diameter of my spindle, around 1" long. Bored a .750 through hole for the stop-shaft. Then I faced the other end to make a flange 1/2" thick. Last edited by widgitmaster; 06-25-2006 at 01:00 AM. |
| Next I drilled a cross hole around 3/8" diameter through both walls of the small diameter. Then I put a pin through it and leveled it in my vise, so that I could run a metal slitting saw through the flange and into the cross hole. This will allow the hub to flex, and not break from repetitive use! Last edited by widgitmaster; 06-25-2006 at 01:00 AM. |
| This whole project was not without incident, as you can see from the images it cost me a 7/8 5C collet! The arbor grabbed and spun in the collet, and cracked the side out of it! The saw is 6" diameter, 1/8" thick running at 70-RPM Last edited by widgitmaster; 06-25-2006 at 01:00 AM. |
| All though the collet cracked, I did manage to finish the cut in the hub! Then I drilled and tapped a 1/4-20 hole through one wall of the large diameter, this is for a set screw to clamp on the stop-shaft, and expand the hub inside the spindle bore! This way I kill two birds with one stone! I put it in my spindle, and ran it at 2000 RPM, it did not cause any vibrations which is good news! Now I can make small ACME leadscrews all the same length with out having to do extra setups for each one! My 14x40 lathe has a 1.6" ID in the spindle, so I used a 3/4" shaft to make it solid! Then I turned one end of the shaft and pressed a block on to it, and turned it to slip freely inside the spindle bore. This gives me one complete flat surface to stop my parts from, wether I use a 3 jaw, 4-jaw chuck or a 5C collet chuck! Hope this gives you some ideas of how easy it is to make a spindle stop! Eric Last edited by widgitmaster; 06-25-2006 at 01:00 AM. |
| looks good, I ended up just turning a peice with a light press into the end of my spindle and use a peice of threaded rod with a jam nut, worked pretty good for the parts I was making, I made about 60 standoff posts that all came out within .001 or less. yours looks a bit better than mine, definately better concept ![]() Jon
__________________ CNC Mini Lathe Plans and Rotary Table kits: http://jfettigmachines.com |
