Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 06-10-2006, 02:14 PM
frank02189 is on a distinguished road
Benchtop CNC mini lathe
HI All
Looks like an 8x14 at 229lbs with a 4" chuck
This should be interesting
frank
Product Features
1. This CNC precision mini lathe is designed to perform various types
of processing jobs. Counterface turning, drilling, threading and
cutting jobs on materials made up of round bar and bar materials can
be performed with this machine. This machine can be used in areas
such as mini precison parts processing, sample processing and
modeling works
2. This machine is DC motor driven
3. The feed speed can be adjusted according to the requirement of
different workpieces, the maximum feed speed can be reached to axes
Z: 3 m/min, axes X: 2m/min
4. The spindle speed is infinitely variable from 100 to
2500/3000/3500RPM programme set)
Specifications
Distance between centres 350mm
Swing over bed 200mm
Spindle taper MT4
Tailstock taper MT2
Chuck diameter 100mm
Spindle bore 25mm
Cross slide travel 72mm
Tool post size 60*60mm
Cutter size 10*10mm
Range of metric threads 0.5-2.5mm
Range of imperial threads 12-52TPI
Spindle accuracy 0.01mm
Spindle speed 100-2500/3000/3500RPM
Power of motor 750W
Voltage/Frequency 230V/50Hz or 120V/60Hz
Net weight/Gross weight 104Kg/130Kg
Packing size 1055*575*570mm
link
http://www.made-in-china.com/china-
products/productviewXeoJnFxrIQtP/CNC-Mini-Lathe.html
company Shanghai Futai Electromechanical Equipment Co., Ltd.
Old 06-10-2006, 02:29 PM
RotarySMP's Avatar
RotarySMP is on a distinguished road
THis will be interesting to see. The MT-4 spindle is a real advatage. If you think about it, there are a lot of parts in a manual lathe (change gears, tumbler reverse) etc which can be replaced by a simple stepper, mount and coupler....
I wonder what software they ripped?
Regards,
Mark
www.wrathall.com
Old 06-10-2006, 04:38 PM
CrazyRonny's Avatar
CrazyRonny is on a distinguished road
Really nice little lathe I like the chip guard.
Do you know the price?
CrazyRonny
Old 06-11-2006, 07:39 AM
JDsto is on a distinguished road
I also want to know the price point on this thing?
Old 06-11-2006, 07:50 AM
RotarySMP's Avatar
I wouldn't mind betting that ball screws were not used.
Regards,
Mark
www.wrathall.com
Old 06-11-2006, 08:56 AM
I haven't seen the price point yet but I'll bet that they weren't used either. There seem to be more options every day.
Old 06-11-2006, 10:07 AM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
How would I get my big fat hands in there to clean it?
There does'nt look like much space between the bottom of the machine and the chip pan!
It looks like a traditional 4 position tool post, is it auto-indexing, or do you move manually?
Eric
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Old 06-11-2006, 12:53 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Intriguing little machine. And yes, it sure looks like an 8x18. There are a couple of nice upgrades in there, such as a camlock on the tailstock instead of just tightening a screw. I find it intriguing that the cross-slide servo/stepper drive looks like a right angle drive. Not sure what the backlash implications of that would be!
I do believe the 9x30 and shorter bed 8x18 variant are the best CNC platforms among the mini-lathes. They are more heavily made than the 9x20's (they don't require the compound modification for rigidity), and the dispense with things like quick change gears out of the box.
Widgit, there is more room than you'd think to get under the bed as it sits on two pedestals at the ends. The middle is hidden by the chip guard and apron, but I'll bet that guard flips up somehow. The travelling guard design would be nifty for anyone with one of these lathes. The controller also looks nicely integrated on the front.
Somehow the chuck looks small to me. The spec says 100mm, which is just under 4". Also, not clear how productive a CNC machine like this would be commercially with some form of bar feeder. It would be perfectly adequate for prototyping, however.
Best,
BW
Old 06-26-2006, 07:31 PM
Green0 is on a distinguished road
That's almost a 1inch spindle bore. Looks cool. What is the price and where do people buy them. That link isn't working for me.
Old 06-26-2006, 07:38 PM
Gold Member
CNC Mini-Lathe
Old 06-26-2006, 08:11 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Question Chinese Mini Lathe
Looks pretty good. But what type of control is that? Doesn't say if it has RS232 or USB interface. Beats the hell out of doing a lot of manual operations.
I wonder if it has an optional programmable tail stock? You might be able to put a quick change tool post in it too.
The Ad says it has a .0004 spindle accuracy.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
  #12   Ban this user!
Old 06-28-2006, 08:04 PM
wizard is on a distinguished road
Interesting but what I'd like to see in a lathe this size is a spindle bored for 5C collets. It looks like they are real close dimension wise so this is a frustration.
The other thing that bothers me is that a slant bed or somehting similar is needed to keep the swarf off the mechanics.
