| Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here. |
| I am using Turbocnc on my converted 7x1 mini lathe. I have done from M6 thru 12x0.5mm metric micrometer thread to internal .938x16tpi imperial. The G77 canned cylce in TurboCNC is great. What do you mean by 0-80 1.2mm? Do you mean thread diameters up to 1.2mm or pitches up to 1.2 mm?
__________________ Regards, Mark www.wrathall.com |
| I forgot a comma. "0-80" is a very small screw. I don't know the name of the numbering system but it belongs to the same numbering system as 6-32. So "0" is the niminal diameter (approx .070" from memory) and it has 80 threads per inch. "1.2mm" is 1.2mm nominal diameter with a pitch of about .25mm ( from memory) somewheres around the size of screws from reading glasses. Anyone done this on a CNC'd 7x lathe? |
| Well there is nothing stopping you from doing small diameter threading work on the cnc, if you've got the manipulation technology to handle the parts without loosing them in the chips. The useful unsupported length of the stock is proportional to the diameter, I guess. This means for a #0-80 screw (.060 OD), that you might be able to thread a stub maybe .125" long, if you are lucky. Much longer than that, then you need a tail-center support, which is very constraining on the distances and diameters you would have to work at. There is also the problem of how close to a shoulder do you need to run the tool? Two threads might be a reasonable stopping distance, that is .025", which is a significant amount on such a small screw. I am awestruck at the manufacturing technology that must be used to manufacture these tiny fasteners, for pennies apiece, and right up to the head, as well. I suppose they are rolled between flat plates like most all other threaded products nowadays, but still, feeding the parts in straight, and so on, is quite an achievement. So far as internal threads, well I've done a fair amount of #0-80 tapping, and it is quite straightforward. I don't even want to think about trying to single-point thread one with a boring bar, though
| CNC is not a magic answer to the problem, if that is what you are wondering. Sure, a cnc gives excellent tool control and so on, but the problems lie more with the support and stiffness of the stock while it is being worked. CNC does not really solve those problems at all.
