Results 1 to 4 of 4
Thread: Mini Lathe
    Feb 2012
    England
    Mini Lathe
    You know the crossfeed leadscrew,what size is the thread?
    I ordered some bits and pieces off the internet,two items were one 10mm tap and one 10mm die.
    basically with me wanting to CNC the lathe I needed to make a longer crossfeed leadscrew and its metric and my caliper says its 10mm well the 10mm die won't screw onto the shaft which it should,so anyone know if its metric or ACME?
    Cheers.
    Feb 2012
    England
    Damn,turns out its a lefthand 10mm metric,shoulda checked but never gave it a thought.
    Thanks for the PM,John
    Feb 2012
    England
    Pondering on this,why is it a lefthand thread? I mean it travels backwards and forwards as a righthand thread would have done as well.
    Registered ninefinger's Avatar
    Sep 2006
    Its intuitive to turn clockwise to move the crossfeed in and reduce the diameter. I think you'll find its pretty much industry standard for all lathes...
    Mike
  1. best way to cut stock for machining on mini lathe/mini mill
    By crazybrit in forum Benchtop Machines
    Last Post: 12-31-2011, 04:40 AM
  2. Mini lathe and mini mill spindle?
    By ZipSnipe in forum General Metal Working Machines
    Last Post: 10-15-2010, 09:13 AM
  3. New Machine Build- My CNC mill with mini lathe performing CNC lathe operations
    By ryansuperbee in forum General Metal Working Machines
    Last Post: 08-20-2008, 02:06 AM
  4. X2 Mini Mill & Mini Lathe - Cummins Tools
    By ccsparky in forum Benchtop Machines
    Last Post: 12-19-2007, 08:54 AM
  5. Anyone have a mini cnc lathe or medium sized cnc lathe
    By nymachinist in forum Mini Lathe
    Last Post: 01-23-2006, 09:36 PM
