Well, at least you can buy your way out of that mistake! There are worse things to be stupid about...
As far as live center - if this is for your mini lathe I would imagine the LMS one will be fine. I can't see loading it enough to need a 3 bearing heavy duty design - you just can't put that much load on these little lathes.
Also - the risk is pretty low @ $15 so go for it and post up a review
my 2 cents...
Mike
LinkBack URL
About LinkBacks
