The issue with a pulley setup on the Sherline Z Axis, is that the column isn't very stiff to start with and any additional weight hanging off to one side of it isn't going to help you out any.
The Sherline is designed to machine small parts, probably only weighs 40lbs total, so the steppers are significant additional weight.
I thought the only difference with the Sherline Z Axis lead screw for CNC, was the addition of an anti backlash nut, which Sherline sells separately. Although I could be mistaken.
LinkBack URL
About LinkBacks
