Results 1 to 4 of 4
Thread: How to remove handwheel from tailstock?
    Mar 2010
    Hi all,
    I have a clone 7x10 mini-lathe.
    I bought a new tailstock casting and wanted to disassemble my old one so I could reuse the other parts. I can't seem to get the handwheel off - I took off the nut and the grub screw but the wheel won't come off.
    Any hints?
    Steve
    Jan 2007
    UK
    Hi Steve. I had the same problem the first time I dismantled my tailstock. The problem was rust between the handle boss and the screw shaft. I managed by holding he tailstock by the handle and gently tapping the shaft with a brass drift (you need three hands to do this!) and it eventually came out. I cleaned up and oiled the two parts and I have not had a problem since.
    Mike
    Mar 2010
    Thanks Mike,
    With your hint I was finally able to get it off - I used a screwdriver and mallet to (gently) get in between the bracket holding the screw and the hand wheel.
    Steve
    Tinkerer
    Nov 2009
    Gear puller?
  1. X-Y table: How do I remove the handwheel from the leadscrew?
    By doorknob in forum Benchtop Machines
    Last Post: 09-23-2010, 02:23 PM
  2. Handwheel Function ?
    By nelZ in forum CamSoft Products
    Last Post: 10-24-2008, 03:10 PM
  3. Need Help!- Handwheel accuracy
    By PhilCote in forum CamSoft Products
    Last Post: 08-14-2008, 07:11 AM
  4. Need Help!- Handwheel command and MPG
    By precourt in forum CamSoft Products
    Last Post: 03-24-2008, 11:14 AM
  5. Handwheel Installation
    By plateroomred in forum CamSoft Products
    Last Post: 05-24-2005, 05:28 PM
