Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: spectra light milling machine
    Jun 2011
    us
    Hello,
    I just purchase 2 spectra light milling machine from a tech school and they did not come with the pci interface card. is there anyone that can help me out ? Do i need to go directly to light machines to get this card? do i have any other options?
    In this purchase i also got an emco compact 5 pc i am looking for any advice on this machine as well. do i need to purchase a seperate interface card for this machine?
    thanks
    Dinis
    Tinkerer
    Nov 2009
    From my experiences you will most likely have to convert the machine. The ISA cards are hard if not impossible to find or so expensive they arent worth it. Do you have the software? A few pictures would always help. There are a few threads here on the zone of people resurrecting those machines and or converting them to moderm electronics to run G codes. Are you comfortable with electronics? Any experience machining or cnc? Plenty here to challenge anyone.
    Jun 2011
    us
    Hello
    I am not that good with electronics but i do have extensive knowledge of programing cnc machines. all be it larger machines but i would think programing is the same.
    i am new to this site so once i figure everything out i will send some photos
    Jun 2011
    us
    I hope this works i just truied to attach photos
    Attached Thumbnails Attached Thumbnails spectra light milling machine-emco_compact_5_pc.jpg   spectra light milling machine-spectra_light_cnc_milling_machine.gif
    Tinkerer
    Nov 2009
    Are those the actual pictures, if so they are nice. My first machine was just like your mill. It is an old Sherline that has been refit. The steppers and screws are reusable but it would be better to get the new Sherline stepper mounts as they have thrust bearings. When I started I had the machines as you but had no experience in machining, CAD, CAM and pretty light on electronics. A few years later, I understand some of it! Do you have the controller box with the mill?
    Jun 2011
    us
    these are not actuals but my machines are in really nice shape. they have been in storage for 10 years and when i check the date of manufacture it was only 13 years ago so the machines only saw about three years of use in a school enviorment. I have 2 of the milling machines and yes i have the control box for both machines. you said they were sherline but i believe the make of the machine is spectra light 0200 mill. which is made by light machine in manchester NH. they are actually part of Intelilink.
    anything you can do to help me out point me in the right direction. i am hoping the lathe I can just plug and chug. the mill i am being told are going to be some work.
    Tinkerer
    Nov 2009
    The lathe was an Emco?, a nice lathe in appearance but I dont know anything about them. I do know that the mill you have within that enclosure looks just like mine. If it is all of the mechanicals should be Sherline. The electronics were all done by Intellitek/Light Machines the way I understood it. I modernized all of mine with Sherline parts. A better picture would clear it up.
    Tinkerer
    Nov 2009
    Have you looked in YouTube? Here is a guy running a similar machine
    You might look there and ask them too! I have done that many times and been helped immensely.
    Jun 2011
    us
    what exactly would you like me to take pictures of? just the inside of the sheet metal? maybe the stepper motors?
    Tinkerer
    Nov 2009
    Maybe a close up of the machine (mill) itself and not the enclosure. Steppers should be Vexta's.
    Aug 2011
    Arrow PCI interface card and other intelitek stuff.
    I'm new to the forum but have been a tech teacher using intelitek machines for 14 yrs. I have an extra PCI controller and ! want a mill or router. Can we deal. I have the control software you need for the mill as well. PM me and I will send it to you. I need spectralight lathe software if you have it.
    I have mapped the pinouts for the cables if you need that info. The 25 pin is a straight through shielded printer cable.
    Good luck finding any info on the wiring and steppers. The guys at Intelitek don't share info worth a crap. They'll be happy to fix anything for you if you send it to them. That said: I have not seen a bad controller in 14 years. Never had a bad interface box either. Have seen some bad steppers. Mostly on the z axis due to kids grabbing the connector and breaking it off. The pins inside the connectors on the steppers are very fragile. I have been able to disassemble and fix the pins on a couple of occasions. I had 8 spectralight mills, 2 prolight mills, 2 routers, 2 expert mills, 2 prolight lathes and 3 spectralathes in my shop when I retired. really miss those routers. Let me know if I can help.
    May 2012
    Hi, I really wish that someone can help me
    where can I purchse PC controller for Spectralight????
    I have one machine that's connected to an old PC with ISA controller card and I want to replace the computer with a recent one but I'm having difficulty finding a PCI controller card
    it seems like it's very hard to find PC PCI controller for Spectralight CNC!!
  • Page 1 of 2 12 LastLast
    1. Spectra light and Light machine owners have ?
      By ZipSnipe in forum Benchtop Machines
      Last Post: 07-18-2008, 10:52 PM
    2. WANTED: SPECTRA LIGHT TURNING LATHE SOFTWARE
      By Maplenut in forum Want To Buy...Need help!
      Last Post: 02-04-2008, 11:13 AM
    3. Did Anyone hear of "Spectra Light Mill Control"??
      By CNCNR in forum General Metal Working Machines
      Last Post: 01-22-2008, 06:28 PM
    4. Replies: 2
      Last Post: 08-27-2007, 09:08 AM
    5. LED Machine Light
      By KaptainKarst in forum General Electronics Discussion
      Last Post: 02-08-2006, 01:57 PM
    Visitors found this page by searching for:
    Nobody landed on this page from a search engine, yet!
    SEO Blog
