Results 1 to 6 of 6
Thread: Compound Position DRO for Mini Lathe
    Jan 2009
    Title should be "Carriage Position DRO for Mini Lathe"
    Turing a particular length on the work piece has always been a challenge to me on my Mini Lathe. With my new addition I can now simply set my start position to zero and crank the compound down the bed for the EXACT distance that I want. All of this because I installed a Linear DRO to measure the travel distance of the compound on the bed.
    All it took was a 6 inch Linear DRO and a couple of aluminum brackets. The left end mounts where the threading position indicator used to be. On the right end I simply mounted a small aluminum angle so that the bracket that came with the DRO could be securely held in place. All holes were drilled and tapped to 6-32.
    See pictures below for all the details.
    George
    Attached Thumbnails Attached Thumbnails Compound Position DRO for Mini Lathe-dro1.jpg   Compound Position DRO for Mini Lathe-dro2.jpg   Compound Position DRO for Mini Lathe-dro3.jpg   Compound Position DRO for Mini Lathe-dro4.jpg
    May 2008
    Just be careful with hot chip flying on the scale, it will burn it.
    Just protect it some way.
    Jeff
    Jan 2009
    Thanks Jeff, I will keep an eye on the hot chips. With the DRO's at the far end I hope a lot of hot chips don't get down there. Time will tell.
    Thanks for the tip,
    George
    May 2010
    did you use digital calipers to make this or something more purpose made?
    Jan 2009
    I got the two linear readouts from Shars, about $55 for the pair, 4 and 6 inch.
    Here is a link to the page:
    shars.com - Horizontal Electronic Scales
    George
    Jan 2007
    Uinted Kingdom
    And the Shumatech DRO could be used to provide a combined total for the two scales ...
    DRO-550 | shumatech.com
    Lester Caine - G8HFL
    http://medw.co.uk - Home of electronics for the Model Engineer
    1. Lathe/MTM tool change position
      By double a-ron in forum GibbsCAM
      Last Post: 12-19-2010, 02:07 PM
    2. Mini lathe and mini mill spindle?
      By ZipSnipe in forum General Metal Working Machines
      Last Post: 10-15-2010, 09:13 AM
    3. New Machine Build- My CNC mill with mini lathe performing CNC lathe operations
      By ryansuperbee in forum General Metal Working Machines
      Last Post: 08-20-2008, 02:06 AM
    4. X2 Mini Mill & Mini Lathe - Cummins Tools
      By ccsparky in forum Benchtop Machines
      Last Post: 12-19-2007, 08:54 AM
    5. Enco Compound Slide Milling & Compound Drilling Table
      By 7ofclubs in forum DIY CNC Router Table Machines
      Last Post: 12-23-2006, 11:43 PM
