Results 1 to 4 of 4
Thread: HF 7x10 MiniLathe - Bar mounting
    Dec 2009
    Hi.
    on the HF 7x10 Mini-Lathe, can you mount a bar through the chuck like you can on larger lathes, so that you can work on the end of a long bar?
    I have some 15" long rods, that I just need to drill and tap the ends of. (But I also want an excuse to get a new toy).
    Registered RotarySMP's Avatar
    Mar 2004
    Vienna, Austria
    Yes. The spindle has a 20mm (approx) bore. The 3" three jaw check which comes with it only has a about a 16mm bore.
    Regards,
    Mark
    www.wrathall.com
    Dec 2009
    Great, thank you.
    Registered knudsen's Avatar
    Feb 2010
    Just be careful the end of a longer bar doesn't start to whip around.
    Wen I was young, I spent most of my money on fast women, slow horses, and cheap booze. The rest of it I just wasted.
  1. cummins minilathe
    By krymis in forum Mini Lathe
    Last Post: 02-07-2010, 05:01 AM
  2. Casting round alum. slugs for minilathe
    By dmerc in forum Casting Metals
    Last Post: 05-21-2009, 11:12 PM
  3. Replies: 2
    Last Post: 01-26-2009, 02:50 PM
  4. Seeking Minilathe QCTP Advice
    By HankB in forum Mini Lathe
    Last Post: 02-08-2008, 09:29 PM
  5. Canadian Source for MiniLathe other than Busy Bee
    By yukonho in forum Mini Lathe
    Last Post: 01-29-2005, 04:00 AM
