| Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here. |
| Q: Non-marring Working holding I was curious how other people are holding finished work without marring it? I've turned down some 6061, then flip it around in the chuck to work on the other end. I get nice little jaw marks on the finished side. I thought about putting some masking tape on the the finished side. I just wasn't sure how that would effect the accuracy of the turned part. The chuck already gives me problems about items spinning exactly true. ((when it's been flipped over)) |
| Professionals use collet chucks or collet pads to grip parts. But wrapping a turn of thin brass shimstock around the part will protect the surface pretty well, too.
| paper works well if your on a budget although its kinda a pain in the butt. Same with shim stock though!
__________________ thanks Michael T. "If you don't stand for something, chances are, you'll fall for anything!" |
| When the configuration of the part allows, I perform all finishing work between centers to eliminate chuck's marks. I also use card stock - like cereal boxes cut into small pads to protect the part from chuck's teeth. When I use pads it is only for light cuts and I will use a live center. I would suggest that all roughing work is done first then chuck lightly for finishing, or finish between centers. For some apps I have used fine sandpaper to provide additional grip. Scott
__________________ Consistency is a good thing....unless you're consistently an idiot. |
| I'm turning the part between centers, but I have to part and face off the ends. I'm fighting with the chuck and it's inability to center the part regardless of how I insert it. It's always a gnat hair off. Ah well. I guess it's a learning experience. = ) Last edited by Deviant; 06-23-2005 at 10:14 AM. |
| working w/ iges file | tom@wave-l | Mastercam | 6 | 07-13-2005 01:57 PM |
| Machine working, Business & Website launched | Moondog | DIY-CNC Router Table Machines | 1 | 02-16-2005 05:25 AM |
| Working with tombstone. | Per_N | General CAM Discussion | 1 | 01-05-2005 01:01 PM |
| Work holding???? | anoel | General Metal Working Machines | 17 | 10-14-2004 01:07 PM |
| Work Holding Methods | InventIt | DIY-CNC Router Table Machines | 13 | 09-14-2004 04:13 AM |
