Results 1 to 2 of 2
Thread: JEWELRY MILLING
    Aug 2010
    JEWELRY MILLING
    Hello, Everyone
    I have been slowly introducing the use of cnc milling machine into our shop. We run a jewelry manufacturing company, where we manufacture wedding bands. Most of the manufacturing work is done on manual lathes, and swiss cut machines. We did use manual milling for a little design work. Now we have started to introduce the cnc milling machines. The potential is huge for product development. The only issue is we are using standard steel, carbide, and coated endmills. The tool paths need to be bright shinny finish, like when we use diamond tools on our lathes. I have been looking for diamond End mills, do they exist, and where can i find them from.
    Any help would be much appreciated.
    Jan 2009
    You might have better luck one forum up (Benchtop machines) since this is a lathe oriented "corner" of the forum.
    Hmmm, the first thing that comes to mind are diamond "burrs" like are used in dremel tools... http://www.widgetsupply.com/page/WS/...el-diamond-set
    Also (And I was thinking on this the other night) I don't see why you couldn't use a felt or rubber buffing wheel, doped in polishing compound and about the same size as your cutting bit to do the final pass on something. http://www.widgetsupply.com/page/WS/CTGY/dremel-polish
    Q: How many tools does it take before a simple task becomes a project?
    A: Just one. I'm the Tool that turns a simple task in to a project.
  1. What software to use for Jewelry
    By Joab in forum General Jewelry Design Software
    Last Post: 03-18-2013, 03:01 PM
  2. Jewelry CAD/CAM Design
    By goldsmith in forum General CAM Discussion
    Last Post: 01-11-2013, 07:10 AM
  3. Jewelry with CNC
    By ashyl in forum Product and Manufacturer Announcements
    Last Post: 08-12-2010, 05:20 PM
  4. Jewelry Making
    By BuckingFastards in forum DIY CNC Router Table Machines
    Last Post: 08-30-2006, 09:49 AM
  5. Jewelry making vid
    By nervis1 in forum CNCzone Club House
    Last Post: 10-08-2005, 12:48 AM
