Just a thot, I've never done cnc, maybe this is standard stuff, but you might consider removing the cross slide from the carriage and design the tool holder to sit on the remainder and use the lead screw for lateral movement. This would increase rigidity and give you more room to make a big honkin' tool holder with a zillion tools on it
You'd be surprised have big of work you can hog through with a 7x, given time and low speed range, that is![]()
LinkBack URL
About LinkBacks
