New here and i have a qustion about this sherline
Results 1 to 3 of 3
Thread: New here and i have a qustion about this sherline
    Jun 2014
    Question New here and i have a qustion about this sherline
    Hello,
    New here I have really enjoyed reading the posts on this form.
    I have a question,
    Recently bought a sherline lathe and mill and would like to know if anyone here knows anything
    About the control box?
    And are these steppers or servos?
    and is this set up ready to run?
    Attached are pictures
    Thanks all
    Daniel Escobedo
    Attached Thumbnails Attached Thumbnails New here and i have a qustion about this sherline-20171210_115217-jpg   New here and i have a qustion about this sherline-20171210_115212-jpg   New here and i have a qustion about this sherline-20171210_115242-jpg   New here and i have a qustion about this sherline-20171210_115221-jpg
    New here and i have a qustion about this sherline-20171210_115229-jpg
    Feb 2007
    Default Re: New here and i have a qustion about this sherline
    Those are stepper motors. You might want to open up the box to see what each of the db25 connectors go to. If you can find documentation somewhere, you should be able to configure it to run on a pc control.
    Member awerby's Avatar
    Apr 2004
    You still need a computer in the system. Sherline uses a linux-based control software which is free to download from linuxcnc.org. You should be able to get the required setup files from Sherline. Here's a document that explains how the software works: MINI GUI
    Of course, if you've only got one control box for both machines, you'll need to switch it over every time you want to switch from the lathe to the mill and back. Be sure to turn everything off and let the capacitors drain before disconnecting and reconnecting the motors.
