Mini-lathe speed control problem
Results 1 to 2 of 2
Thread: Mini-lathe speed control problem
    Oct 2006
    Default Mini-lathe speed control problem
    I have a HF mini-lathe (it is old) that developed a speed control problem. When I turn the control knob to very low RPM it jumps to maximum. When I move it to a faster RPM it eventually goes back to normal. It is kind of scary when this happens and a workpiece is in there!
    See a video of the problem...
    Thoughts on what on the control board is failed?
    Thanks!
    Sep 2005
    Default Re: Mini-lathe speed control problem
    Do you have a bad pot or wire connection? Those are the first items I would check.
    Robert
