Build Thread 7x14 cnc conversion
Page 1 of 11 1234 ... LastLast
Results 1 to 12 of 125
Thread: 7x14 cnc conversion
    May 2010
    England
    Talking 7x14 cnc conversion
    Ok im gana be converting my 7x14 minilathe to cnc over the next few weeks/months, i was in the middle of building a plasma/router table then i got this lathe as a christmas presant from my GF (yup, a GF that buys machine tools as christmas presants, shes definatly a keeper) so the plasma is on the back burner till this lathe is finished. this particular 7x14 is from Amadeal £380 inc VAT has a 550 watt motor 100mm chuck and camlock tailstock also has spindle rpm readout.
    this is what i intend to achive.
    Ballscrews on X and Z.
    Spindle speed control by Mach3.
    Spindle index pulse for threading/rpm input to Mach.
    Full enclosure with a slideing door at front for access.
    Flood coolant controlled by Mach.
    And possibly an auto tool turret but will be useing a QCT to start with.
    Up to now i have done most of the X axis. il be useing a 200oz-in stepper and a class5 ballscrew 8x2.5 pre loaded. the nut is only 17mm Dia so no prob fiting it under the cross slide. the Z axis will have a 16x5 ballscrew same class and preloaded and a 425 oz-in stepper, both axis are direct drive. im hopeing the drivers and BOB will arrive tomoro from Worldofcnc and the Z screw and bearing supports later this week. il take some pics of the cross slide tomoro and upload them, heres a few pics of the spindle index and what will eventualy be my coolant tank (deep fat frier that never got used and so claimed for my project )
    Let me know what you all think, any advice,tips,questions, please feel free to chip in. (il need lots of advice on the electrics side of it)
    Attached Thumbnails Attached Thumbnails 7x14 cnc conversion-lathe-pics-smaller-size-002-jpg   7x14 cnc conversion-lathe-pics-smaller-size-003-jpg   7x14 cnc conversion-lathe-pics-smaller-size-004-jpg   7x14 cnc conversion-lathe-pics-smaller-size-005-jpg
    7x14 cnc conversion-lathe-pics-smaller-size-007-jpg   7x14 cnc conversion-lathe-pics-smaller-size-001-jpg
    May 2010
    England
    Does anyone see a potential problem haveing 2 optical switches so close together? am also worried that the bottom one is close to the spindle moter and might be affected by electrical noise. the one thats mounted to the little green pcb is the original one that came with the lathe for the rpm readout, i wanted to keep it on there so i can mount the lcd screen that comes with the lathe on the control pannel that il make wich will have Estop,cycle start buttons and other things. the switch at the bottom is the one i fitted that will go to my BOB for mach3. still not sure how to wire this switch to my BOB, i do know i need a separat 5v power supply and some 220 resisters but wich wires go were i duno, its an optek OPB917BZ
    May 2010
    England
    Ok heres some pics of the almost complete X axis cross slide. still need to machine a 6x1 thread on the front of the ball screw and machine the other end of it to fit the 7mm ID rear support bearing and 6.35mm motor coupler. might try useing the tool post grinder to machine the back of it, this stuff is a pig to machine with carbide tip tools, have to re sharpen them every few passes
    I decided to put the stepper at the back as it overhanges the bed less this way and i think the flat bed way will ware less than the V bed way would with the same amount of weight as i think the V shape ampilfies any weight put on it causing increased ware and the weight of the apron at front will help to ballance things out.
    im useing a double row angular contact bearing at front, 30ODx10IDx15Wide, smaller would have been better but thease were smallest i could find and only £7.50 from worldofcnc. rear bearing is just a standard bearing 22ODx7IDx7Wide.
    Drivers didnt arrive today, hopefuly tomoro. cant tell you exactly what type of drivers they are cos i duno myself, but the guy at worldofcnc told me they would run a 425oz-in stepper wich is the biggest il be useing on this machine, heres a link to the drivers Controller Kits
    Attached Thumbnails Attached Thumbnails 7x14 cnc conversion-lathe-pics-2-001-jpg   7x14 cnc conversion-lathe-pics-2-002-jpg   7x14 cnc conversion-lathe-pics-2-004-jpg   7x14 cnc conversion-lathe-pics-2-005-jpg
    7x14 cnc conversion-lathe-pics-2-007-jpg   7x14 cnc conversion-lathe-pics-2-008-jpg
    Registered TXFred's Avatar
    Aug 2009
    Austin, TX
    Quote Originally Posted by Simon C View Post
    They should be fine. I built an optical ignition for my motorcycle using two sensors. They're much closer together and they never have crosstalk issues.
    And optical sensors are good at ignoring electrical noise. I think it will be fine.
    Nov 2007
    Lookin' mighty nice Simon!
    May 2010
    England
    Thanx for your reply TXfred, you put my mind at rest. I guess that is the ultimate test for an optical switch being so close to the HT leads on a motorbike and still functioning properly.
  7. #7
    May 2010
    England
    Quote Originally Posted by blades View Post
    Thankyou Blades.
  8. #8
    May 2010
    England
    Well i finished machining the X ballscrew today, i found a little trick to machineing thease more easily. trick is you just gata be brave and take deep cuts, i was being to catious and only takeing mabe 0.04 - 0.08 mm per pass but this just tends to just "pollish" the cutting edge very quickly. it cut much better when i was takeing 0.7 - 1 mm per pass. now just have to bore out and cut a m15 x 1 thread in the ball nut mount and mount a home switch and the X axis will be finished. gana use the same type switch for the homes as i did on the spindle index, Optec OPB917BZ, optical interupt switch, still have no clue how to wire thease to a BOB yet lol. Also orderd the spindle control board yesterday Zapp Automation Hope it works with the BOB im useing, has anyone had any experience with this particular board?
  9. #9
    May 2010
    England
    Well i finished the x axis today and hooked it up to the Hobby cnc board that i use to run my mill. Doesnt appear to have any backlash but il check that later with my DTI. also made some heavy duty gibs for the z axis out of 20mm x 10mm cold rolled square bar, not sure if this is the best materiul to use for gibs, only used it cos i had some lieing around. Still havent recieved the Z ballscrew or the drivers and BOB so not alot i can do till they get here, mabe il work on the coolant system till they arrive.
    Heres a coupple pics of the completed X with the 305 oz-in motor. the Xbox 360 u can see in the pic was gutted and now has a hobby cnc board and 38V psu in it, gana use the original Xbox psu to power the coolant pump it puts out 12V 12.1A it also has a 5V 1A output that i might beable to make use of. coolant pump im useing is a 12V submersable Diesel transfer pump that i have lieing around.
    Attached Thumbnails Attached Thumbnails 7x14 cnc conversion-lathe-crossslide-003-jpg   7x14 cnc conversion-lathe-crossslide-002-jpg   7x14 cnc conversion-lathe-crossslide-001-jpg
  10. #10
    May 2010
    England
    This is a link to a youtube vid of a test i did to check for backash. rapid speed was 2300mm/min if i remember correctly, probly would go faster. hobbycnc pro board on half micro steps with 38V ps. the drivers il be useing on the finished machine are 1/10th micro steps so the motors should run much smoother i hope. [nomedia="http://www.youtube.com/watch?v=Mbqzr6ouufc"]YouTube - CNC Mini Lathe conversion Backlash Test[/nomedia]
  11. #11
    Registered eartaker's Avatar
    Aug 2009
    Awesome work going on here. What are your plans on covering the screw?
    Jermie
  12. #12
    May 2010
    England
    Quote Originally Posted by eartaker View Post
    Thankyou eartaker,
    Im planing to make a cover out of sheet metal that will be longenough to cover the stepper aswell, it will kinda wrap around the whole of the motor mount and cover the rear part of the top of the cross slide, not sure if this will cause motor cooling problems or not. i dont have a sheet metal bender. so il buy a small one. have been looking at this one New Page its the one at top of the page. only problem with this one is i plan to make a full enclosure for this lathe so with this small bending machine il have to make the long parts in 3 pieces and silver solder them together, the longer benders seam to get very expensive as they get longer, idealy i need one that will bend 36" long.
7x14 cnc conversion
7x14 cnc conversion
