Build Thread Cam lock Tail stock for 7x12 - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 25 to 36 of 37
Thread: Cam lock Tail stock for 7x12
  1. #25
    Registered RotarySMP's Avatar
    Mar 2004
    Vienna, Austria
    ...then extended.
    You can see that the vertical alignment is now a little low (Ram not concentric to casting? Play between casting hole and ram?, and gets progressively worse as ram extends (Ram angled down?).
    Attached Thumbnails Attached Thumbnails Cam lock Tail stock for 7x12-049-shaft-centering-top-jpg   Cam lock Tail stock for 7x12-050-shaft-centering-fwd-jpg   Cam lock Tail stock for 7x12-051-shaft-centering-lwr-jpg   Cam lock Tail stock for 7x12-052-shaft-centering-aft-jpg
    Regards,
    Mark
  2. #26
    Mar 2004
    Vienna, Austria
    Then I looked at the rams angular alignment, both horizontally...
    Attached Thumbnails Attached Thumbnails Cam lock Tail stock for 7x12-020-side-align-fwd-jpg   Cam lock Tail stock for 7x12-021-side-align-aft-jpg
    Regards,
    Mark
  3. #27
    Mar 2004
    Vienna, Austria
    ...and vertically.
    The ram, or at least it's outer surface, is reasonably well aligned vertically (less than a though over 2 ") , but about 0.0025" misaligned horizontally. I can't remember how bad it was before I started in 2004, but I guess I have learned a bit more about precision in the last 6 years.
    Attached Thumbnails Attached Thumbnails Cam lock Tail stock for 7x12-031-top-align-fwd-jpg   Cam lock Tail stock for 7x12-032-top-align-aft-jpg
    Regards,
    Mark
  4. #28
    Mar 2004
    Vienna, Austria
    While doing this I took a little detour into looking at the rigidity of the thing.
    There isn't much!
    With a single finger I can push it through 0.005" sideways, and that was with the quill locked. Vertically it is better.
    Unlocked the range of movement is about the same, but not force is required.
    Attached Thumbnails Attached Thumbnails Cam lock Tail stock for 7x12-010-max-side-push-jpg   Cam lock Tail stock for 7x12-011-max-side-pull-jpg   Cam lock Tail stock for 7x12-013-max-top-push-jpg   Cam lock Tail stock for 7x12-014-max-top-pull-jpg
    Regards,
    Mark
  5. #29
    Mar 2004
    Vienna, Austria
    I also did checks with a dead center and with a mill shaft chucked in the drill chuck. The results shed no new light on things. Good news was that it makes little difference how the mill shaft was chucked, or in which rotation the chuck morse taper was installed in the tail stock, the basic misalignment stayed pretty repeatable.
    So I cooked out the superglue, and measured the shims I used in 2004. 0.008" of paper shims on the front mating surface, and .013" of metal and paper shim on the rear. Nothing one the vertical alignment face.
    My aim was to add 0.001" front and rear to raise it up, and a thou to the rear of the vertical alignment face to kick it around straight with the ways.
    I then spent a whole evening removing and installing the whole thing about a million times with different stacks of shims, made from 0.010" brass shim stock, 0.004" beer can, and 0.0004" household food wrap foil.
    This was frustrating, but I ended up with a good feel for the repeatability, and plan for how I'll attack the horizontal adjustment for the final assembly.
    Plan is to get a good shim pack, and then do a wet final assembly with epoxy, where I get the thing aligned during the gel time of the adhesive.
    Wish me luck
    Regards,
    Mark
  6. #30
    Registered Crevice Reamer's Avatar
    Mar 2008
    Good luck Mark!
    CR.
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
  7. #31
    Mar 2004
    Vienna, Austria
    Default One piece tail stock
    Thanks CR. I am sure that helped.
    I managed to get it centered within about 0.0003" horizontally (with the quill retracted), and about half a thou high. Since the error increase as the quill extends, and I have no way to measure whether the morse taper is aligned to the quill outer surface. I decided this would be enough.
    Well here it is, the candy coated one piece tail stock.
    I have about 20L of JB Weld epoxy structural filler which was getting tossed at my old job because it was life ex. Well, although it expired in 2004, it still hardened fine for this job. That hour in the oven at 70°c probably helped.
    I figured I'd do the surface filling with it rather than bog, since:
    1/ I have this.
    2/ I don't have bog.
    Attached Thumbnails Attached Thumbnails Cam lock Tail stock for 7x12-img_6966-jpg   Cam lock Tail stock for 7x12-img_6967-jpg
    Regards,
    Mark
  8. #32
    Mar 2004
    Vienna, Austria
    Man, do I hate painting things. I sanded back the blue epoxy filer and the undercoated with a rattle can. Looked good with a couple of minor defects, which filled in the next three coats of undercoat. Sanded back with 600 grit wet between each coat.
    On the third coat got some fish eyes/ pin holes (not properly dry before the coat?), so I didtwo more coats trying to fix that.
    The green paint (also a rattle can) came from a model store a few years ago. When i sprayed that it looked okay, but with fish eyes and pinholes again. So I sanded that back off, diluted some of that blue filler with acetone and filled the defects, then undercoated again. The under coat dissolved the bits of green which were not completely sanded off. I wish I was smart enough to heed this waring over paint incompatibility.
    Once I got those defects sanded back and another coat of undercoat applied and sanded back, I put on a couple of top coats. They didn't come out as well as the original coats with the fish eyes (wish I had called it quits back then).
    I sanded the green a little with 1000 grit wet, and then put on coat of clear gloss.
    Big time incompatibility.
    Now I have ignored it for a couple of weeks, trying to decide whether to sand it back and do it properly, or accept that it is a turd and is supposed to look like one.
    Attached Thumbnails Attached Thumbnails Cam lock Tail stock for 7x12-img_6971-jpg   Cam lock Tail stock for 7x12-img_6975-jpg
    Regards,
    Mark
  9. #33
    Mar 2008
    Quote Originally Posted by RotarySMP View Post
    DITTO!
    Good effort, but:
    I don't know how to break this to you gently: The tailstock takes a lot of dings. No matter how good you get the finish, if you actually USE it, sooner or later turner's rash will begin to degrade your paint job.
    Put that thing together and make some chips!
    CR.
  10. #34
    Mar 2004
    Vienna, Austria
    Yep. I already have put it together.
    I polished the turd as practice for the day I get a real machine which is worth doing up. When that day comes I'll be painting it with epoxy paint.
    I used that same crap green paint on my enclosure. What a waste of time, as it now looks like hell. I only painted it because it was mild steel sheet, and picked up rust easily. Once you spray a bit of cutting oil around, rust is a no longer a concern.
    When I make an enclosure for the mill, I am not going to paint the inside of the sheet metal. Swarf is a great paint stripper.
    Attached Thumbnails Attached Thumbnails Cam lock Tail stock for 7x12-img_6885-jpg
    Regards,
    Mark
  11. #35
    Mar 2004
    Vienna, Austria
    I forgot to post a photo of the finished product.
    Attached Thumbnails Attached Thumbnails Cam lock Tail stock for 7x12-img_7212-jpg
    Regards,
    Mark
  12. #36
    Mar 2008
    She's a beauty! Nice Work!
    CR.
