Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 01-10-2010, 08:32 PM
koppjb is on a distinguished road
error code 201
milltronics milling machine VK3 will run all drill cycles but will go to DOS trying to run any mill cycle.Deleted all program files and uploaded parameter file.Same problem could anybody help.THANKS
Old 01-14-2010, 08:23 AM
jpawelk is on a distinguished road
Error 201 is a Range Check Error. Something (parameter, program input, etc..) is out of range or too large. The DOS error contains an address number and software version. What is this?
Old 01-14-2010, 08:47 AM
Hi Jpawelk
The DOS version is 6.22 and the address is 0019:15BD
Old 01-14-2010, 09:09 AM
The software version of the Milltronics software, not the DOS version.
Old 01-14-2010, 11:02 AM
Hi Jpawelk
3 AXIS SLS CNC 6.3159p FLASH
Thank you
Problem- error code 017 musnar HURCO 5 10-13-2009 08:20 AM
Unknown g code G23 error? keaton64 Mach Plasma / Laser 3 09-21-2009 09:33 PM
ps 101 error code help! AC_Engineering Bridgeport and Hardinge Mills 2 11-13-2007 06:01 AM
art code error Mike Boarman Mach Software (ArtSoft software) 4 12-30-2006 10:46 PM
M01 error code MRU Mazak, Mitsubishi, Mazatrol 2 06-12-2006 07:59 AM
