| Milltronics Discuss Milltronics Machines |
| Can someone tell me how to adjust my upgraded Centurion 1 machine so that it is able to have a coordinate system that aligns with the one in this code? (Or otherwise, so that this 401 error is addressed) I bought a machine recently and the planing program was still on the hard drive which the previous owner was using successfully. Given that the program is OK it would seem that the solution to this problem would come from an adjustment somewhere in the parameters. Thanks for any help. |
| An error 401 indicates that you are trying to move the X axis out of its travel limits. The problem may lie in the program, make sure that there is no excessive X axis moves. If you are using cutter comp, make sure that the tool diameters are set correctly. Make certain that you have set the work coordinates properly. If that is not the case, please make sure that the positive and negative limit parameters are set properly for your machine. These parameters can be found under F4(AXIS) after you open the machine parameters up. |
| Tags |
| centurion, error 401, milltronics, x axis limit over travel |
| Limit Switch Overtravel | kolias | DIY-CNC Router Table Machines | 11 | 06-30-2009 12:22 PM |
| Overtravel Error that won't go away! | andywids | Fanuc | 7 | 01-29-2009 11:56 AM |
| Error 403 Z axis software limit overtravel | designerpatrick | Milltronics | 6 | 02-12-2008 08:57 AM |
| BOSS 8 random axis limit error | rkdygert | Bridgeport and Hardinge Mills | 12 | 03-17-2007 12:03 PM |
| +/- Overtravel error for all axis | claucampan | Fanuc | 2 | 08-08-2006 06:11 PM |
