Results 1 to 4 of 4
Thread: Help with setting a parameter.
    Sep 2009
    We are cutting electrodes in a milltronics VM-20 and were wondering if there is a way to change a parameter for the Z height in the NC file? What we want to do is put the height of the electrode in this offset so it will lift all tools to the top of the electrode. Also, at the end of the NC file set this value back to zero. Any suggestions out there?
    Thanks,
    Matt
    Jul 2004
    I don't know about inside the nc program, but you can change z work coord. on coord page.
    Jan 2006
    G52 Z# (to shift Z up/down)
    Sep 2009
    Thanks Tim,
    I will give this a try, at first glance it looks like ( in the controll ) it will work. I will try it once our machine it back up and running, bad motor bearing, but at first glance in a quick hand written program it looks like it works to me. Here is a small piece of code to see what I am trying to do.
    % ( VM-20 ELECTRODE NC FILE )
    ( SET TRODE HEIGHT )
    ( CHANGE 6.0000 TO WHAT THE TRODE HEIGHT IS)
    G52 Z 6.0000
    O0000
    (PROGRAM NAME - TEST)
    (DATE=DD-MM-YY - 05-10-09 TIME=HH:MM - 23:15)
    (MCX FILE - NEWFILE)
    (NC FILE - C:\DOCUMENTS AND SETTINGS\MATT\DESKTOP\TEST.NC)
    G32
    G20
    G0 G17 G40 G80 G90
    ( 1/2 BULL R.030 TOOL - 4 DIA. OFF. - 4 LEN. - 4 DIA. - .5 )
    T4 M6
    PB208=0
    PB81=2
    G0 G90 G54 X1.5473 Y-.39 S8500 M3
    G43 H4 Z.5 M37
    Z.1
    G1 Z0. F15.
    Y.11 F250.
    G3 X1.0473 Y.61 I-.5 J0.
    G1 X-1.4646
    G3 X-1.9646 Y.11 I0. J-.5
    G1 Y-.39
    Z.1 F500.
    G0 Z.5
    M5
    M9
    PB81=0
    G32
    G40
    G53 Y0
    G52 Z 0.0000 ( NOW SET G52 Z BACK TO ZERO )
    M30
    Thank again and I will re-post when I get a chance to test it.
    Matt
  1. CAPPS Parameter Setting?
    By xenginebuilder in forum Mori lathes
    Last Post: 04-25-2009, 10:37 AM
  2. parameter setting help
    By luis cuellar in forum Haas Mills
    Last Post: 07-18-2008, 12:39 AM
  3. Need HELP with chuck direction parameter setting
    By Eagle View in forum General Metalwork Discussion
    Last Post: 01-25-2008, 10:30 AM
  4. simens 840D system parameter setting
    By a_ravi_tn in forum G-Code Programing
    Last Post: 04-16-2007, 10:39 PM
  5. G76 Parameter setting
    By Gorrell in forum Fanuc
    Last Post: 01-29-2007, 03:21 PM
