Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 08-17-2009, 10:09 AM
Brian FRF is on a distinguished road
machine oiler, slow
Ive got voltage to it, and all is correct, but using oil very slowly. Its the right oil as well. Im wondering is the plunger adjuster should be showing more or less shaft to pump more oil? Right now its got a good 1" of shaft showing. Every other machine Ive used only has a touch of shaft showing. I can also see the plunger going up and down, so I know its moving.
Old 08-17-2009, 05:51 PM
avtechmachine is on a distinguished road
Is your machine lubepump look like attach picture? sound like very close the same, this lube pump if you need to increase or decrease lube oil, just break loose the set screw on the plunger and remove the snap ring, turn plunger CW or CCW to increase or decrease oil each time it pump
Ahn Vuong
Old 08-18-2009, 12:06 PM
Real similar. More shaft showing mean more or less oil?
Ahn Vuong
Old 08-18-2009, 12:12 PM
jpawelk is on a distinguished road
Please see the attachment concerning oiler adjustment.
Old 08-18-2009, 12:20 PM
More shaft showing which plunger will go up higher when pump, mean more oil
Ahn Vuong
Old 08-18-2009, 01:25 PM
BlueChip's Avatar
BlueChip is on a distinguished road
Way Oiler
Here is a short article that might be a good reference :
http://www.kentechinc.com/tip1.html
auto oiler help MarshCustom General Metalwork Discussion 0 03-04-2009 10:32 AM
BIJUR OILER tpmx57 Bridgeport and Hardinge Mills 5 06-08-2008 05:33 AM
Newbie- Button Oiler - How to use. Eric Q. Shopmaster/Shoptask 7 03-15-2008 12:40 AM
Slow machine response inquiry spoiledbrat Mach Mill 5 01-30-2007 09:05 AM
Timer / oiler question chrispy Mach Software (ArtSoft software) 5 08-21-2005 10:36 AM
