| Milltronics Discuss Milltronics Machines |
| Yes, I can see a file 09020 would that be the macro for the tool changer? If so How do I open up that file? or send it to the floppy?. The problem I am having is that my tool changer is not functioning under and M6 command. There are 2 things it will not do and that is homing the tool changer and spindle orient. M20&M19 Thanks john |
| John, The tool change macro would not affect a M20 or M19. These M codes are found in the tool change macro however. Try commanding the M codes separately to see what happens. It may possible that the control already thinks your tool changer is at home and/or the spindle is oriented. Look at the diag on the control to help you with this. |
| I have tried the M codes individually in MDI and the only 2 that will not do anything is M20 and M19. M20 should rotate Tchanger till it sees the prox switch for home. It does not do this.Also on my tchange page I have CW and CCW but no home button. M19 will only rotate spindle if you had a RPM programmed into it before but then it will spin at that RPM and not stop. That is why in the tool change macro there is S0M05 before M19. I bought this machine used and it seems someone has been messing with it. I have everthing working but the Tchanger and am stumped at this point. Thanks John |
| "difference between Custom Macro A and Custom Macro B" | arulthambi | Parametric Programing | 4 | 10-05-2009 04:34 PM |
| Need Help!- Macro A or Macro B On fanuc o-md | macrosat | Fanuc | 1 | 07-29-2009 07:49 AM |
| Testing program for Macro (Fanuc Macro B) | NickDP | Fanuc | 2 | 03-27-2009 04:15 PM |
| Need Help!- macro | msantaji1 | Fanuc | 7 | 01-02-2009 02:57 PM |
| Convert Fanuc Macro to Fadal Macro | bfoster59 | Fadal | 1 | 11-09-2007 12:41 AM |
