Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 08-12-2009, 08:53 AM
Joe Miranda is on a distinguished road
Constant Surface Speed w/RPM limit
In conversational mode I can program my lathe with constant surface speed and and RPM limit so that I can run, say, at 300SF with a max RPM of 1200. Is there a way to do that in regular G-code so that I can do simple stuff manually - like when I face off one end of a part to give myself a reference.
Joe
Old 08-12-2009, 09:05 AM
HuFlungDung's Avatar
Moderator
G50 S1200
Old 08-13-2009, 12:58 PM
Thanks Hu! It worked.
Constant surface speed Bergen CNC Daewoo/Doosan 4 07-13-2008 03:10 PM
Constant cutting speed macro MrWild Dolphin CADCAM 4 06-10-2008 06:18 AM
constant surface speed mr.mark General Metalwork Discussion 3 10-03-2007 03:21 PM
Scripting a constant offset curve over a contoured surface? Splint Rhino 3D 11 03-11-2007 05:35 AM
Constant Surface Speed raymond1 Bridgeport and Hardinge Mills 9 01-07-2007 11:17 PM
