Dear Flathead
Here is the info on my machine:
Milltronics 4D with Centurion5 controller. It comes with VFD, coolant pump and look like it has been modified to accomodate auto tool change.
I did some research on servo drives, hopefully I should have the specs and wiring diagram within a day or two.
I will post some pics soon.
I am planning to use MACH3 with a breakout board( any suggestions) which can control coolant pump, VFD, etc. Also I am planning to use a seperate PLC for it (any suggestions?). and most probably I am going to buy the pendant.
The goal is to retrofit this machine to a workhorse with fully functional control and the budget $ is not a issue here.
My next machine is 10X5 ft
CNC router( The mechanics are 95% ready, and I a planning to put controls on by January 2010)
Keep in touch and any information shared is appreciated.
thanks
osdhillon
