Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 05-14-2009, 10:14 AM
panaceabea is on a distinguished road
starting in the middle of a program
I just have a couple of quick questions on accessing, editing and running a program from a mid point with the cent 7 controller.
how do I jump to the middle of the program loaded to run , make changes and then choose the point I want it to run from , like a tool change etc.
Do I need to know the block number or can I visually scroll thru it looking for known points?
If I can scroll thru and pick a start point in the program loaded will the controller dry run thru and look for the offset and tool that needs to be loaded?
Old 05-14-2009, 09:12 PM
Farmers Machine is on a distinguished road
Are you programming in conversational or G code?
if conversational the event is the block such as start mill event # 3
go to run,start and then you have 3 choices, first, block " event" and tool#. answer ? accordingly and the green box will tell you block so and so or tool# has been found push cycle start to start program from here. if you are not starting from a tool change or tool call make sure the proper tool is in the spindle and the proper tool # and the tool offset # are displayed in the info box.
good luck
The Farmer
Old 05-14-2009, 10:39 PM
I am running g code files pieced together from mastercam files , handwritten files and files written with another cam program.
in most cases there are n ot line numbers or the same line number might appear dozens of times do to cutting and pasting in a text editor. Some of the files I am running are quite large and not easy to modify on the desk top and dnc back to the machine. I am working with forgings and I need to be able to edit in the machine on occasion
On both my other milling centers , haas and bridgeport, I can scroll thru the program line by line and edit at will and then run from the highlighted line. Is this possible with the cent7 controller?
Old 05-14-2009, 11:47 PM
HuFlungDung's Avatar
Moderator
Wow, those programs sound like a real mess to look at
You might look at some software that may help you. I'm thinking of NCPlot, which is a quite intelligent simulator that may actually help you with renumbering the code in a meaningful way that might make it easier to sort out subroutines and such. I don't have NCPlot myself, but I think it attempts to run through subs in a meaningful fashion that will show you if you've got things in proper order.
If you can get the program renumbered properly then you'd have a lot easier time at the control.
Old 05-15-2009, 10:12 PM
I have ncplot and at least one other program that will renumber , thats not my concern .
I am just wondering how to scroll thru the program line by line in the cent 7 controller, and when I find the line I want , can I highlight it and start from that point.
If it is possible to scroll thru line by line and run from a selected point how do I do so and is it possible to pick single inputs in a line ( x4.00 ) etc and delete them then replace with a new value ?
I have not done anything with the milltronics other than dnc large programs with the editor in mastercam and run them, but some of the programs are rather large and take 2+ hours to transfer, I occassionaly need to make some simple changes based on dimensional differences in the forgings without spending hours reloading the program.
In the hAAS controller all I have to do is open the program, push edit and I can scroll line by line thru the program with the mpg wheel or the arrow keys, highlight what I want to change, hit delete , type in the new value and hit enter and its inserted. Does the cent 7 controller allow this process or something similar?
Old 05-16-2009, 01:26 AM
Originally Posted by panaceabea View Post
.....In the hAAS controller all I have to do is open the program, push edit and I can scroll line by line thru the program with the mpg wheel or the arrow keys, highlight what I want to change, hit delete , type in the new value and hit enter and its inserted. Does the cent 7 controller allow this process or something similar?
You do know that on the Haas you can simply type in the entry you want to change and push the down cursor to jump straight to it? No need to spend time with the wheel or arrow keys
Old 05-16-2009, 11:01 AM
I did not know that Geof ,How do I do that, do I have to have and know specific line numbers?
Is their a find and replace?
Old 05-16-2009, 12:55 PM
I am assuming the basic text editing ability does not exist with the milltronics?
Old 05-17-2009, 06:50 PM
call 952-442-1401 Milltronics service dept. there is a way to restart like you want to but they will have to explain how. I either use Gibbs cam with N numbers or conversational at the control and it is simple.
good luck
The Farmer
Old 05-17-2009, 07:12 PM
Thanks, I will give them a call. I normaly just make changes on the desktop either manualy or in mastercam but at 2+ hours to dnc some of them back in the machine I def need a way to edit files in the machine that were not created with the conversational programing .
I figured the milltronics guy that watches this section would have chimed in by now
  #11   Ban this user!
Old 05-19-2009, 02:06 AM
atultapkirkar is on a distinguished road
Are you talking about the conversational program or text program? You can run the text program from any block. Here is a sample progrm..
N10G90G0X0Y0Z200.
N20(TOOLPATH PSRCA-24)
N30(TOOL NAME :- DIA3.0 BALL)
N40 (TOOL DIA :- 3.00)
N50 (TIP RADIUS :- 0)
N60 (MAT'L THICKNESS:- .05)
N70(TOOLPATH TIME :- 1142)
N80X20.574Y-11.847S7000M3
N90Z-10.5M8
N100G1Z-11.F300
N110Y-11.846F1500
N120X20.593Y-11.828Z-10.985
N130X20.775Y-11.646Z-10.957
N140X20.855Y-11.566Z-11.
N150Y-11.565
N160X21.053Y-11.297
N170X21.052Y-11.298
N180X20.949Y-11.401Z-10.834
N190X20.851Y-11.499Z-10.745
N200X20.642Y-11.708Z-10.694
N210X20.454Y-11.896Z-10.78
N220X20.344Y-12.006Z-10.913
You can just scroll down to the block you want. Or you know Z value (how deep your program run). If you cut upto 20mm deep, then you can serch the block containing Z-20 or Z-19.5. You can serch it in edit mode by hitting MISC then FIND then put Z-20 then enter 2 times.
In above program the block numbers are in the increment of 10. So if you edit a block and change its bolck number to the intermediate value (if you are editing block number N180, after editing you can change it yo N171 to N179 and N181 to N189. Because in large text programs these block numbers are repeatative and your edited bolck number is identical.)
So post the text programs in the increment of 5 or10.
To run the progrm from the the desired posision, first hit RUN then START then BLOCK then type the block number eg. N171 then hit enter then start. But before that you must start the spindle manually or type the spindle speed and program feed in that block.
  #12   Ban this user!
Old 05-19-2009, 09:54 AM
Thank you , Thats exactly what I was looking for . I must have been unclear in my questions above. How do I enter edit mode?
locked up in middle of program nmn Haas Mills 9 03-30-2009 10:33 PM
starting from the middle of a program panaceabea Haas Mills 8 03-27-2009 07:31 PM
Starting in the middle of a program.Old control. lostkoss General CNC (Mill and Lathe) Control Software (NC) 3 10-07-2008 10:11 AM
Hass VF6 how do you stop in middle of program SpringKing Haas Mills 5 05-14-2007 11:07 AM
Starting in the middle of a line with pathfinder tahlinc Tahlcam 0 10-02-2003 07:26 AM
